2002 C240 Air conditioning not working?
Took it to a mechanic who, for about $650 replaced the blower (said it was fried), and it started blowing cold air, but only out of the center.
Took it back, and they said it was probably that the actuators were stuck.
Later that day, I stopped getting air of any kind...hot, cold...nothing...whether the AC is on or off.
The mechanic said it is probably the control module that isn't working. New one + labor will be about $750
I like the car...it isn't my main car, but I really don't feel like spending a ton of money on AC issues if they aren't going to solve the problem.
So, my question is: What do you guys think? Is the control module the likely culprit?
Take your car to dealer and have them scan it with Mercedes Star Diagnostics (do not ever trust those cheap general readers and mechanics guessing what could or would be wrong). This will cost you something around $30-50 and you will for sure know what is the problem.
If it is the actuators/stepper motors, then Star will indicate which ones are broken. Also control module errors would be shown there. Now your mechanic is guessing between actuators ($1000 job to tear dash) or $750 with the module problem. It is way too big range of guesses so the scan @ dealer is not expensive but their quote for the job might be :P
Good luck
It isn't even blowing, so while I will take it to a MB dealer when I can get an appointment, any idea why it wouldn't be running at all?
Talked to another mechanic who said it is probably the control head itself. Just curious...how difficult is it to replace one myself...I'm only slightly handy and not interested in a huge project. But if it is like a 30min-1hr deal, I will give it a go. Not sure how common it is for AC/Heat problems to be related to the control unit itself, but an aftermarket /used unit is pretty cheap, so might be worth a shot.
(I tried the 'reset' trick where you hold down the defrost and recirculation buttons and it blinks for a while...mine didn't stop blinking, so something is screwed.)
The MB dealer told me it would be $189 to go over the AC system...seems steep.
