Disabling emergency turn signals
Is there a way to disable your fogs from being used as a turn signal when the main turn bulbs blow?
It is a safety feature. Why would you want to disable it?
just replace the broken bulb asap...
but i do know that if a turn signal bulb blew, the ticker inside your car would tick at double-speed, just like any other car.
but look at it outside, and it's still running at regular speed.. save from the embarassment of a dead bulb
also, at the rear, if for example, your left tail lamp bulb blows, it'll substitute it with another bulb from your left cluster. the right side will match so that it'll be even
AMG BRED - something to watch out for.
The only thing they're good at is using the expensive DAS machine to play Solitaire.
Yes you can but you have to go to the dealer for it and disable bulb substitution feature in the system. It's a saftey feature they added for all vital bulbs.
I would like to diable it because I am planning on putting HIDs in my fogs, but fear that if a bulb blew my ballast will fry...
