Anyone seen these lights?
Old Feb 10, 2004 | 11:59 AM
Jim Banville's Avatar
'06 Lexus GS300 RWD, '07 Camry SE V6 auto, '91 190E 2.6 auto
Click here
Are they any good? Any other recommendations for similar wide angle LED's?
Old Feb 10, 2004 | 02:34 PM
Xeon's Avatar
we still need the load resistor right?
Old Feb 10, 2004 | 03:20 PM
jlm003's Avatar
2009 Porsche 911 Carrera S
Jim,
Don't know if yours is any better that the link below, but it might be an alternative...
http://www.led.net/datasheets/auto_index/auto_index.htm
Old Feb 10, 2004 | 05:26 PM
Jlm003, the thing is the one's I posted are about 3x cheaper than the ones at Ledtronics. I believe neither comes with a warranty.
Old Feb 10, 2004 | 06:11 PM
Rick's Avatar
C230K Coupe/Orion/C4/C5/CD/AMG Spoiler/V60/TeleAid, 2 MGB's
wait...why are you asking about TOYOTA mods in a MERCEDES forum???
Old Feb 10, 2004 | 06:49 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Because he knows that the smart ones with all the correct answers reside on this forum.
Old Feb 10, 2004 | 07:56 PM
True
I know you guys have a lot of experience modding your rides. BUT, this isn't a Toyota-only mod, otherwise I wouldn't post it
Jim
Old Feb 11, 2004 | 10:43 AM
bagwell's Avatar
From: Houston,TX-moving to The Woodlands,TX SOON!!!
Toyota Tacoma & Lexus IS250
Hey Jim - how is that Toyota....I bet its perfect....no problems right !!!!!!
what kinda MPG you getting?
Old Feb 11, 2004 | 12:01 PM
The only "problem" I've found is that the leather on the top of of the second row seats has a wrinkle in it. I'll try to pull it out myself. I haven't had a chance to check MPG yet since my wife drives it most of the time and does the fuel fill ups. Everything seems to fit together and works as it should! Oh yeah, I think I have heard some distortion on the front left speaker on occasion, but it isn't repeatable.
Old Feb 11, 2004 | 01:40 PM
vadim's Avatar
'19 GLC 300, '19 TM3SR+
You don't need a warranty for LEDs - they never burn out.
Old Feb 11, 2004 | 04:43 PM
I have read at least one post where someone said the LED bulbs they bought died within a short time period. The LED's themselves may not burn out, but I'm concerned about the quality of the other parts and their construction. I've also heard that not all LED's are of equal quality. I'm curious if Ledtronics LED lights are $36/each because they are better than the $13 ones, or are they just overpriced?
Old Feb 11, 2004 | 04:51 PM
vadim's Avatar
I guess if they are DOA, it's a different clause - defective merchandise. But you are right - conductors may get loose or corroded if poorly made.
Old Feb 11, 2004 | 05:39 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
I've seen someone used it on his 3-series. It doesn't work very well. Very unsafe when you are on the side of the car because you can't tell if the turn signal is on or not.
Old Feb 11, 2004 | 09:44 PM
FrankW, are you POSITIVE that he is using these wide angle LED's rather than the more commonly available narrow angle LED's? Seeing as how the 'directionality' of LED's is such a complaint, I wonder why someone doesn't make a light with a couple rows of outward facing LED's, and fewer rearward facing ones, like this crude picture?
Jim
Old Feb 11, 2004 | 10:08 PM
Even easier would be a small round piece of plastic that is convex in shape and has a translucent mirror finish like that on mirrored sunglasses. A couple of tiny platic arms would hold it about 1/2" from the face of glowing LED's, with the convex mirror facing the LED's. The round mirrored surface would redirect the light to various parts of the reflector, while you would still get some direct rearward light from the rearfacing LED's since the finish on the plastic is translucent. In other words, it's like holding up a lens from a pair of mirrored sunglasses up to the beam of a flashlight. Some of the light striking the mirrored finsih is going to get redirected back toward the flashlight at various angles, while some of the light will still pass right through the lens. Seems like it would only cost a few cents to make. Such as if you apply a finish to the clear cup shaped plastic that holds plastic toy jewelry, etc. in those coin operated "bubble gum" machines. Can you get a translucent mirror finish "paint" in a spraycan? How about misting the plastic "cup" with a metallic paint like some people do to amber bubs when they put them behind clear lens's so you don't want see the amber color, yet the bulb still glows amber when it's on?
Old Feb 12, 2004 | 08:54 PM
Outland's Avatar
2002 C230 Coupe(M111)
BULL****.
One of my city light LED bulbs burned out. There are 4 on the circuit board, and one went south...after that the rest just flickered.
Old Feb 12, 2004 | 09:17 PM
vadim's Avatar
Originally posted by Outland
BULL****.
If you knew the principle of operation of LED, you'd look for the reason of your disaster elsewhere.
An LED is a solid-state semiconductor device with absolutely nothing to burn out or suffer from vibration inside it - unlike incandescent bulbs or even HID. The only way to destroy an LED is to apply voltage much higher than what it is designed to operate at -or- to create improper conditions for heat dissipation so it gets overheated and suffers a thermal damage which is irreversible.
Flickering most likely means poor soldering.
Somehow I am not surprised that LED-based lighting devices go bad - like everwhere else, there are scores of cheap makeshift companies rushing into this "hot" market - hence, the result.
I guess Jim's remark about the necessity of a warranty on these things really makes sense...
Old Feb 12, 2004 | 09:28 PM
Outland's Avatar
I understand how they work just fine thank you. But nothing is impervious to failure.
Ive seen em crack, Ive seen ones that the leads break off of....there's more to 'burning out' than internal failure. Even still, solid state components also have a finite lifetime...not to mention manufacturing flaws.
Its a wedge replacement bulb. It has 4 LED's. One will not light at all. The other three flicker.
Old Feb 12, 2004 | 09:44 PM
vadim's Avatar
Yes, guaranteed lifetime for an average LED is around 10 years - way ahead compared to any other lighting device. As for manufacturing flaws - this is all about quality control, and this is exactly what I meant in the previous post - cheap companies couldn't care less about quality rushing to make a quick buck.
The bottom line is: if you have a working LED and put it in nominal conditions - it will NOT burn out.
Old Feb 12, 2004 | 11:04 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
Jim
he has the single direction LED bulbs oppose of the one that's posted on the first page of this thread. I wasn't paying attention at the picture and thought you guys are talking about the single direction ones.
Old Feb 13, 2004 | 05:44 AM
Rick's Avatar
IT STILL SOUNDS LIKE A TOYOTA PART - NOT SOMETHING A PERSON WOULD USE ON A MERCEDES! RICE!!!!
Old Feb 13, 2004 | 05:56 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
WHY??
The S-class has LED tail light, the SL has LED tail light, the BMW 3-series now has tail light consist entire of LEDs, the 7-series also has LED tail light, and the facelifted C-class will soon have LED tail light.
Old Feb 13, 2004 | 09:59 AM
Rick, why do you mention Toyota? Seems that most compact sports cars I see that are "riced-out" are Hondas/Acuras, followed by other brands. I rarely see a Toyota-ricer. Are you trying to make some childish personal jab at my Sequoia? Is that the kind of person you are? Have I made any deragatory remarks about MB's or their owners?
Old Feb 13, 2004 | 10:34 PM
Outland's Avatar
I think this was a bit out of line...we aren't talking about blue front turn signals after all...
