Unknown port
Old Oct 15, 2015 | 11:49 AM
Garik Ayvazyan's Avatar
Mercedes Benz C240
Unknown port
Hello,
Please help to identify what is this?
I have found it at the down of right front door....
Little history: I want to connect my handset/mp3 player to the car in order to listen music via them, so I started to search smth like AUX port...
Mercedes Benz C240 W203 2001
VIN: WDBRF61J62F180129
Thank you.
Old Oct 15, 2015 | 06:30 PM
Cruel-Merc's Avatar
2009 C350
Not sure what that is , but if you're looking for the auxiliary cable, its white and not black.
Old Oct 15, 2015 | 06:40 PM
Mercedes Benz C240
So, every C240 cars has AUX cable? maybe I'm searching in the wrong place?
Old Oct 16, 2015 | 11:19 AM
VVF's Avatar
VVF
2005 C230K(sold), Mk7 Jetta
2001 most definitely does not have an AUX cable.
Old Oct 16, 2015 | 02:16 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Unless you have command there is no aux port.
Your choices are, hack the stock radio,
instructions are here somewhere.
2. Use a cassette tape modulator, they even have BT ones.
3. Use an RF modulator, thats what I did,since I have audio 20.
Mine is in the dash but still hard wired.
Old Oct 16, 2015 | 08:28 PM
Rubenc87's Avatar
Mercedes C230 K
RF modulator might be the easiest way.
Old Jan 23, 2016 | 10:06 AM
Mercedes Benz C240
Which modulator you are using? And are you satisfied? Mine works but with little noises and without normal bass.
Old Jan 25, 2016 | 02:26 AM
DACHIGGA's Avatar
2002 CL203
In case anyone is still interested in know what the plug is,
It's the d2b wake up wire distribution block. Connects the d2b wakeup from the back of the head unit to all the d2b equipment ie. cd changer, bose amp etc.
