Wrecked 2004 c240...
Old Feb 27, 2004 | 10:17 AM
zluster's Avatar
http://klode.com/Kws/AimsWebApps/Uni...StockID=670337
Its a little surprising the airbags didnt blow, but it looks like the impact missed the frame rails, so it just kinda crunched into the nice soft stuff above them.
Old Feb 27, 2004 | 10:31 AM
tifosiv122's Avatar
SLS AMG | S65 AMG | GL550
Any other car the airbags would have gone off...for some reason MB fails to think that an accident like this needs the bags...
Erik
Old Feb 27, 2004 | 10:52 AM
revstriker's Avatar
K Car
Without knowing the details of the crash, it's hard to judge whether or not there is fault with the airbags. What if the car was parked, and someone ran into it?
Old Feb 27, 2004 | 10:54 AM
mctwin2kman's Avatar
Oh this again. That accident should not have blown the air bags anyhow as the front end went under whatever it hit. Therefore instead of a dead stop which would have fired the airbags, the vehicle continued to move forward under what it hit thus not stopping instantly. The Crumple Zones also look to be untouched, only the hood acted as a crumple zone instead.
Erik, why do assume that MB does not want to fire the airbags, did you ever think of the fact that maybe the crumple zones are more effective on a Benz instead of just firing an airbag in your face. I personally don't even want to see an airbag fly at my head again. The sometimes do more damage than they prevent. Such as for people wearing glasses, or broken wrists from clamping on the wheel before impact and then the airbags blowing your hands off. Air Bags were not designed to deploy in low speed or low damage accidents. They were trully designed to supplement the seatbelt and save your life in a higher speed collision where you are more likely to die or be severely injured.
Old Feb 27, 2004 | 01:00 PM
zluster's Avatar
Exactly...
Dont assume that airbag should have blown because it LOOKS bad, in reality the airbag system takes several data points into consideration when deploying the airbags, the end result is that they are only deployed when nessasary.
The first airbag system blew with only one triggering device, newer systems use multiple sensors to determine when the bags whould be deployed, for instances second generation ford air bags systems use 2 sensors, one a crash sensor on the front, and another a vehicle decelleration sensors in the cabin, both sensors must be triggered for the SRS computer to send the delpoy signal.
Look at this:
This did not deploy the airbags...why not? Well why it may look bad the actualy impact was with a road barrel full of sand. So the actual impact and decelleration to the vehicle was little.
Point being, just because an accident looks bad doesnt mean the airbag should have blown. I trust the airbag computer(even more so on a benz) to determine when the bags should be delpoyed.
Old Feb 27, 2004 | 01:32 PM
tifosiv122's Avatar
I know full well where the sensors on a benz are...we had a 5 year lawsuit with Mercedes over this issue.
Our '89 E class was involved in a head on collision with a Buick.
The Buick was totaled and the airbags went...the Benz had $5K worth of damage but the bags never opened. The owner of the Buick walked away fine...my mom has permanent neck and spine damage. Besides the bags not opening, her belt didn't 'pop'.
Basically MBs stance is in order for the bag to open the entire engine needs to be forced almost into the ****pit.
I have seen hundreds of accident pictures and most of the MBs the airbags did not go off when similar looking accidents of other makes all went off. In our case the extent of the force was equal to both cars so both or none should have gone off.
You might ask why we owned 4 MBs since the accident...well thats because I know from past experience they hold up well and my parents liked the idea of using MBs money to buy cars with...
Erik
Old Feb 27, 2004 | 02:38 PM
In 89 the airbags were **** compared to todays though. They had all kinds of problems not only with MB but other manufacturers. Also I have seen an ML rear end someone with no visible front end damage but both bags deployed. I am not sure what sensors or where they are in a Benz. But as stated above the sensors must trigger simultaneously. Years ago it was the center sensor which was an accelerometer type and the ball type for the front, at least one front and the center one had to fire simultaneously to get the bags to deploy. Now they have this multi stage crap and who knows what makes them go now. Sorry to hear about your mom, but that was of course in the infancy of the airbag being in vehicles. It was not even federally mandated til either 89 or 90 that airbags be in a car. Hopefully the one in my 190E never needs to go off, since is 18 years old.
Old Feb 27, 2004 | 04:06 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
a lil sidetrack, but isn't it after certain amount of years, the airbags need to be replaced? on my w202...in the drivers side door jamn, it says in 2009, the airbags need to be replaced. Is this on MB's dollar (ya right)? or do we have to pay for it ourselves?
Old Feb 27, 2004 | 05:22 PM
revstriker's Avatar
K Car
If this is true, I would bet that it's on your dollar!
Old Feb 27, 2004 | 05:39 PM
tifosiv122's Avatar
Yes there is a "shelf-life" on bags and it's up to you to replace them. Newer one's might last longer but the original ones do need replacing after about 10 years.
As for the bags being old technology in 89, that might be true, but her accident wasn't until 93 and the case ended in 98 when bags weren't as new. The data we collected for the case was from the years before 89 until almost 98. After the settlement my parents bought their new Benz at the same time I bought my SLK.
I am not scared or anything...in my mind if the bag opens on a Benz that means the accident is enough to kill you...the cars are strong and I feel secure because of that...it's not like a toyota that will just crumble.
Erik
Old Feb 27, 2004 | 06:29 PM
zluster's Avatar
......It was not even federally mandated til either 89 or 90 that airbags be in a car..........
It is still not a federal regulation that airbags are required in new vehicle.
Supplementle restraint system(SRS) have been require since 1993 for the drivers side, and 1994 for passenger. This is not nessesarily airbag, passive seatbelts qualify too, you know. Those annoying ones that zip back in forth when you turn the key on? Or just passive seatbelts that do not require you to unbuckle and buckle them everytime you get in the car.
Old Feb 27, 2004 | 09:22 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
agree with what mctwin2kman and zluster said. doesn't look like the car actually hit the bumper instead it hit the sofest part of the front end. that car probably dived under some truck or something.
Old Feb 28, 2004 | 12:34 AM
zluster's Avatar
Ya...
Ya, you can even see the frame rails behind the bumper. The main body wasnt impacted, meaning that the probability of unibody damage is low.
Old Feb 28, 2004 | 02:25 AM
Mike T.'s Avatar
2005 smart cabrio; 2008 Mercedes-Benz B 200
mmm
OK, even a Corolla has similar test score to a W203 in both the EuroNCAP and other crash tests. Plus a new Corolla beats the *** off a W202. Just crumble.
Old Feb 29, 2004 | 12:39 PM
zluster's Avatar
oh and about crumple zones...
......the cars are strong and I feel secure because of that...it's not like a toyota that will just crumble.....-tifosiv122
Which would you rather have:
A car which remains completly rigid during an accident, meaning all the transfer of inertia happen to the occupants of the vehicle which are getting thrown around inside, heads being smashed into windshields, doors etc.
Or a car which fold up like an accordian in the front and rear crumple zones, so that the brute force of the inertial change is transferred to the car, not the occupants.
Old Feb 29, 2004 | 03:32 PM
session's Avatar
2007 VW GTI
The idea that a strong frame will protect you in an accident is a myth. As has been said, it is much better for the car to absorb the energy of a crash than the driver.
Old Mar 1, 2004 | 01:10 AM
zluster's Avatar
MMMMM 350z.....
dont do this:
http://klode.com/Kws/AimsWebApps/Uni...StockID=624679
Old Mar 1, 2004 | 05:16 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
Originally posted by zluster
MMMMM 350z.....
dont do this:
ouch...that's some roll over alright...
Old Mar 1, 2004 | 05:24 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
of course, but I think he meant that MB generally has better chassi design as the passenger compartment is stronger than those of the...say Lincoln Continental or other cars that doesn't do as well. Of course I doubt he doesn't know that it's much better for the car to absorb the impact of the crash, that's what crumble zones are for.
