W203 M271 - Location of timing chain tensioner
Old Apr 10, 2016 | 12:21 PM
Klaufi's Avatar
'05 C230 Kompressor - Sport
W203 M271 - Location of timing chain tensioner *Answered*
Hello everyone,
I know there are alot of threads about the timing chain on the M271, however i have not found the answer to this question.
Where the hell is the timing chain tensioner?
I believe it's supposed to be behind the alternator.
I shouldn't need to remove the timing chain cover right?
Is it possible that there is a small plastic cover, circle-shaped, pushed into a hole covering the head of the tensioner?
Is there any special procedure in installing the new tensioner?
Hopefully someone knows this, i had a skip on one of the cams and am in the process of replacing the chain and tensioner.
Thanks in advance,
Old Apr 10, 2016 | 01:20 PM
Russell Ormerod's Avatar
not a merc
Yes it's behind the alternator. You will see a black round rubber looking plug. Knock a hole in soft centre of it. Lever it out. Then a 17mm socket to remove the tensioner. Good luck
Old Apr 10, 2016 | 01:21 PM
not a merc
Check gears for wear and replace
Klaufi's Avatar
Thank you very much!
Just wanted confirmation before i knocked it out!
Old Apr 20, 2016 | 02:45 AM
tags's Avatar
W203 M271 2003 C230 Kompressor
http://benzbits.com/M271/TimingChainTensioner.pdf
