HELP!! Buzzing Humming Sound from 2005 C230
Old Jun 27, 2016 | 02:59 PM
C230WAK's Avatar
05 C230, 15 C300
I have a 2005 C230 with over 270,000 miles. The engine runs great except for the occasional P0420 code. However I have a buzzing/humming sound coming from somewhere whenever I get up to around 35 mph.
I thought is was the front wheel bearings because whenever turn left on the highway to go around a left hand curve, the sound goes away. The sound is always there when I go straight or turn right. But I changed both the front wheel bearings and the sound is still there. Then I thought it was possibly because the front tires were worn on the inside so I changed the tires, the control arms, the tie rods and got a wheel alignment and the sound is still there.
I'm convinced now that the sound is coming from the rear. One of my many questions is, would the sound from a bad REAR wheel bearing go away when I change direction? And is a rear wheel bearing a DIY job? I also read somewhere that someone was getting a buzzing sound from the rear differential.
Any help or hint would be appreciated.
Old Jun 28, 2016 | 07:52 PM
Preet's Avatar
E63 AMG W211 & W203 Sport Pkg
i would guess the rear diff
Old Jun 28, 2016 | 10:07 PM
LexBrett2's Avatar
2007 Mercedes E550
The sound could literally be anything. The only way to diagnose is to get under the car. It could be something really obvious like a loose heat shield. If you take it to a mechanic and just say you hear a noise might as well give him a blank check
Old Jul 17, 2016 | 12:14 AM
C230WAK's Avatar
05 C230, 15 C300
Rear wheel bearing
Does anyone know if the noise from a bad REAR wheel bearing would change if the car swerves or turns? The from my car completely goes away if I swerve or turn the car to the left.
Old Jul 17, 2016 | 03:43 AM
Russell Ormerod's Avatar
not a merc
check the left rear wheel bearing. if you turn left it will unload the left wheel yes.
Old Jul 22, 2016 | 10:55 PM
C230WAK's Avatar
05 C230, 15 C300
Left rear bearing
I checked the left rear wheel and it is solid with no play at all. I wonder if it could still be cause of the noise.
Old Jul 23, 2016 | 03:52 AM
not a merc
and if you rotate it. does the bearing feel smooth as silk
Old Jul 23, 2016 | 07:34 AM
C230WAK's Avatar
05 C230, 15 C300
There is no play in the wheel. It feels ok when I rotate it. I got the rear end on jack stands so that the rear wheels are off the ground, I put the car in Dyno mode and then put the car in drive. I didn't hear the humming sound with the rear wheels off the ground. I heard an intermittent scraping or scratching sound but it seem to be coming from both sides. I'm assuming that is just the rotors.
Also I'm assuming that I didn't hear anything because there was no pressure on the bearings. I don't know.
Old Jul 23, 2016 | 03:16 PM
not a merc
I meant rotate it by hand to feel
Old Aug 9, 2016 | 03:43 PM
C230WAK's Avatar
05 C230, 15 C300
Fixed
You were correct. It was the left rear wheel bearing. I took off the knuckle with the hub attached and when I spun the hub, it sounded horrible. I bought a used knuckle, with the hub attached, from a salvage yard and now my car is back to being quiet. I had to change the bushing on the used knuckle but that was surprisingly easy with the Sir Tools M0085 tool. Thank you for your help.
Old Aug 9, 2016 | 04:19 PM
RWDlifer's Avatar
2005 C230K SS
A brand new bearing is about 50 bux, why are you going with a used one that might go out a few months down the road? When I did mine I got the 2 bearings for less than 100 bux shipped, removed both rear hubs and took them to a machine shop to get the bearings pressed, cost 50 ish bux. So for about 150 bux I have new bearings (also did the knuckle bushings) that I don't have to worry about.
Plus, if one bearing went out, the other side is close behind.
Old Aug 9, 2016 | 04:35 PM
C230WAK's Avatar
05 C230, 15 C300
I got the used knuckle for $40 and I felt lazy. lol But I will replace the bearing in the knuckle that I took off the car. I just wanted a quick fix because I wasn't sure that was the only thing causing that racket. But you are definitely correct replacing it with a brand new bearing would have been the best option.
