Staggered look
Old Mar 12, 2004 | 11:26 AM
x-tian-230k's Avatar
CLK500/Range Rover HSE/E55 AMG/Bmw 328Xi coupe/BMW 4.8x/Bmw 335i/GS350/Audi S5/E350
Staggered look
Everyone, i just purcheased the brabus of taiwan monoblock V's. They don't come staggard, but i bought different size tires. I have 225/40/18 in the front and 255/40/18 in the back. Do you think that would make the rims look staggered? Should i put in spacers to make them look bigger in the back? Let me know your thoughts.......
Old Mar 12, 2004 | 11:34 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
if u put wider tires on the rears, it'll look wider from the back...
i don't think they'll look staggered from the front/side since the lips are the same on fronts and rears...
Old Mar 12, 2004 | 01:07 PM
what about spacers...can i put spacers?
Old Mar 12, 2004 | 01:13 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
yes, u can add spacers...
Old Mar 12, 2004 | 01:19 PM
Would you know what size if i have 255 in the rear?
Old Mar 12, 2004 | 01:27 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
that i dunno...
anyone w/ 18s or 19s wanna jump in here?
Old Mar 12, 2004 | 01:29 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Thru using I came across peeps using no bigger than 265 on their oversized rims. So, an educated guess would be 5mm, with a 10 mm possibilty depending on drop and load.
Old Mar 12, 2004 | 03:57 PM
netboy's Avatar
2003 C320 coupe/c450 in Feb 2016
y y y
if u want the staggered look, u should get staggered rims in the 1st place!
i got 235/35/19 front, 275/30/19 rear. is bigger better? i think the standard is 265/30/19 for rear.. but i got 275/30/19 rear..
Old Mar 14, 2004 | 03:23 PM
CHATMANR's Avatar
Veteran: Navy
From: From Oxnard; living in Ocean View Hills, San Diego, CA
'01 C320 SS
Originally posted by netboy
y y y
netboy,
275's? What tire are you using? Are you running 9 1/2's in the rear? If so, what offset did you get?
Old Mar 14, 2004 | 07:41 PM
netboy's Avatar
"275's? What tire are you using? Are you running 9 1/2's in the rear? If so, what offset did you get?"
i using Hankook tires, yes, 9 1/2 for rear, offset 37mm on 2003 C320 coupe
Old Mar 14, 2004 | 08:24 PM
Sponger's Avatar
It ain't gonna look right. The rears will look like balloons with the same width rims all around. Use the same size tires at all corners so you can rotate them
