timing marks please help!
Old 08-21-2016, 11:24 AM
nofear300zx's Avatar
2005 C230k
2005 c230 1.8 i have torn down the front of the engine to replace the balance shaft chain due to it broke. there are two gears with marks on them but I cant find any other marks to line them up with. Everything I have read is to pull them chain threw with the old one well I cant do that it snapped. Please help me identify the marks so I can put it back together in the correct location.
Old 08-21-2016, 11:42 AM
RWDlifer's Avatar
2005 C230K SS
Some pics would help a lot here...and your VIN...
Old 08-21-2016, 12:59 PM
2005 C230k
On the 2 small gears there 2 marks but nothing to line them up with
Attached Thumbnails timing marks please help!-20160821_123643.jpg   timing marks please help!-20160821_123631.jpg   timing marks please help!-20160821_123530.jpg
Old 08-21-2016, 01:14 PM
2005 C230k
Here's a better pic
Old 08-21-2016, 04:04 PM
2005 C230k
Figured it out if anyone else is doing it its pretty easy they need to be horizontal facing the idler pulley
Old 08-21-2016, 04:08 PM
2005 C230k
Pic of my setup if anyone knows anything different please let me know waiting in gasket set
Old 08-21-2016, 04:29 PM
RWDlifer's Avatar
2005 C230K SS
I'll dig up the WIS instructions for this in a bit...looks good man...
Old 08-22-2016, 12:57 PM
RWDlifer's Avatar
2005 C230K SS
This is what the WIS image looks like....appears the notches are to the left...
Sorry I couldn't put up a screen shot
EDIT...never mind, the WIS image is upside down.
Attached Thumbnails timing marks please help!-imag0127.jpg   timing marks please help!-imag0126.jpg
Old 08-22-2016, 08:30 PM
Icebreaker's Avatar
2021 E 350
Looking at the photos you might want to replace the gears also, especially the drive gear (at the crank) as they look pretty worn out. Some of the teeth are worn short which could potentially make the new chain slip. By the way isn't the 1.8 a crasher motor? Have you run an air pressure check to test for bent valves?
Old 08-22-2016, 09:02 PM
2005 C230k
I didn't run a air leak test don't have the set up and I didn't notice the worn sprockets thank you for pointing that out to me. I bought the car knowing that it didon't runfound the chain broken plan was to put it on and fire it up see if there were any other issues since the chain broke that runs the oil pump.
Old 08-22-2016, 10:10 PM
Icebreaker's Avatar
2021 E 350
Here is a link to another poster to confirm my query.
https://mbworld.org/forums/c-class-w...erference.html
Sorry to be a bearer of bad news...
Old 08-23-2016, 05:16 AM
2005 C230k
Timing chain was intact the balance shafts chain was the one broken
Quick Reply: timing marks please help!
