limp mode problems
before i fitted the new maf it didnt matter if car was switched on or of the problem was still there.
Thanks for any replies in advance.
P0105 Pressure sensor plausability (current and stored)
One car was started after codes were removed took for a test drive - it drove perfect for about 2 miles then went. Guy scanned it on return and it showed the above code and :-
P1470 - 32 Charge Pressure Stored Control Variation ( charge pressure too high )
I replaced MAP sensor took for test drive and lasted about 20 miles car was flying. Pulled up outside the house reversed into space tried to rev it in neutral and it had gone again into limp mode.
So my question is after reading up on the high boost pressure it states it can be caused by split hoses etc. Surely this would cause low boost pressure. I would have thought it would be more along the lines of blocked dpf or CAT.
Thanks in advance lee (swansea)
With regards to the over boosting error what should i be looking for. have checked the actuator is moving up and down on start up and it does only time it hasnt moved was once out of about ten and at that time it was in limp mode.
many thanks for the reply.lee
Last edited by chippy wood; Jun 13, 2017 at 02:55 PM. Reason: didn,t finish the post
internal electric check of component Y3/6Y2 (shift pressure control solenoid valve)has failed.So took out the tcm and checked wiring and plug fitted correctly,cleared code and went for test drive and everything working ok. So don,t know how it fixed itself but might be worth a try, thanks for the replies I got.
Steve
