2007 C230 Sports Code P2006 and P0128
I have posted in this forum when I had issues with my old 1997 c280 ,that car has been totaled due to a lady with Elantra decided I should no longer have that car.
I have a 2007 c230 sport now ,bought it from a dealer here in San Diego ,all looked good ,test the car with pro (??) ,paid 9.5 all together with 109k on it .
Everything was fine until I drove my first 800 miles ,all I did in the mean time was replaced all four rotors and pads.it did not feel right at the time of purchase.
All of a sudden I got P2006 and P0128 , when I start up the car after a 2 week break, so I reset/delete them codes ,both codes came back on about 200 miles ,so I reset /delete again ,came back on again around 220 miles .
I have a few friends who are willing to help fixing the car using youtube
Now I am ready to replace the coolant thermostat (code 0128)
my question is do I need to replace the whole assembly or just the thermostat ? do I need to replace the sensor as well ?
As for P2006 ,I'm not sure what to do ,it comes up as (Intake Manifold Fumble Flaps) . i don't even know what that is
Are all these code related ?
And yesterday there was a huge new problem as I was coming to a slightly uphill ,which I drove this car and my other car for few years ,yesterday I felt my car wasn't going the way it has been ,stuck at 40mpg ,will not go up ,finally when I passed the so called uphill and went in to a ramp/exit ,wait on a red light,the car shut off the engine , dashboard looked like the key was in #2 position ,there were cars behind me and blowing horn, I quickly put the gear in park and restarted the car ,it started and I was home ,then my wife took the car for some local drive ,it was fine .it was onle a couple of miles . so this morning I noticed it took a long time for temp at dashboard to go up ,eventually it did.on the way back I was extremely cautious ,kept myself to the side ,there was bumper to bemper traffic all the way ,most I drove was 50miles /hr ,probably for a couple of minutes .
so coming thru that same spot ,today I also feel car was being a little sluggish and I passed the light where it stalled yesterday ,I thought I was good today ,it the car shook a little bit engine turned off at the next light ,I did what I did yesterday and came home .
My friends tell me I need a new Cram Position sensor (which does not give a CEL)
My question to you guys is
a. do I need to replace camshaft position sensor ?
b. do I need to replace coolant temp thermostat (P0128)
c. What is a Intake Manifold Fumble Flap ? (P2006) is it an expensive fix ?
d. can they all related ?
any help would be greatly appreciated
if you have any questions please let me know and please do not get bored with my post ,I tried to put as much info as possible
I read some of the posts and threads related to the codes on this forum .I just wanted to be sure
Thank you very much
Thank for your reply
So if the engine turns off at a stop sign twice in two days and starts right back up ,its not the Crank position sensor ? I think I posted as "Cam Shaft" in an error
I want to be sure before I order any parts ,I am definitely getting the coolant Thermostat . do I need the whole assembly or just the thermostat
Did you have the same issues as I did ?
Wahler 100 c should be good ?
Thank you for your help ,appreciate it very much
No problem! Check the whole reference of the part that you got but this is the one that I used.
https://www.youtube.com/watch?v=fI0NFj6FEQE
NP
I found a mechanic out of craigslist ,yes craigslist ,he is a full time Ferrari mechanic but knows a lot about Mercedes ,owns a c55 and cars like Alfa's.
Anyway he was on medical leave and was bored ,wanted to do some work on the side.
He is the most knowledgeable Mercedes guy (or any European) I have ever met ,I mean this guy knows his sh**.
He drove away with my car from the garage ,promised me the car will be like new again.
He did the following and used Starcom
Cleaned EGR Cleaned and repaired manifold Purge manifold /fuel injector Reset tranny shift Swapped coolant temp sensor Changed oil/Filter Fuel Filter pressure checked ,replaced fuel filter Replaced Air Filter Reset transmission and programmed a better map Replaced 4 vacuum lines Re-torque thermostat
Flaps were closed ,he opened them
Suggested not to use Arco gas ,recommended using Mobil or Chevron ,55% 91 and 45% E85,
and I have been following this religiously.
Also recommended I get a new Manifold and upgrade kit in the future.
Car has been running like new ,I mean new ,so far I drove about 1000 miles (I don't drive a lot) ,no CEL since.
He believes car was off loaded due to P2006 but I had the last laugh
His price was less than half of any Indy mechanic would have charge me and extremely honest.
He will be my guy from now on
If yes, where did you buy it? Please give me some more information about it because i'm on the same boat. Thank you!
he did the following
