2002 Mercedes C230K stuck in limp mode even after replacing conductor plate
Old May 11, 2017 | 06:10 PM
mbismylife's Avatar
2002 Mercedes C230K
My car switched to limp mode and started throwing P0715 code -->input/turbine speed sensor A circuit and the check engine light was on. I went ahead and replaced the conductor plate and 13 pin connector. But it is still stuck in limp mode. Checked the wiring that goes into TCM. the wiring was covered with oil, but none went into the TCM and looked clean. Sprayed electrical connector cleaner to make sure the plugs and wiring are cleaned. Even after all this, i still get the code. I tried to erase the code with an OBD2 Scanner, but check engine light turns back on.
Need help. Have no clue what to do next
Old May 12, 2017 | 02:14 AM
tjts1's Avatar
C320
You need a mercedes specific scanner that can speak to the transmission directly in order to clear that code. I used an icarsoft i980. P0715 is a generic engine code that basically tells the engine theres something wrong with the transmission but the code is stored in the TCM. You need to clear the code in the TCM which most generic OBD2 code readers won't do.
Old May 12, 2017 | 07:34 PM
mbismylife's Avatar
2002 Mercedes C230K
tjts1
"You need a mercedes specific scanner that can speak to the transmission directly in order to clear that code. I used an icarsoft i980. P0715 is a generic engine code that basically tells the engine theres something wrong with the transmission but the code is stored in the TCM. You need to clear the code in the TCM which most generic OBD2 code readers won't do."
Thank you for the information. So having code erased through the specified scanner should fix the problem?
Old May 12, 2017 | 07:48 PM
tjts1's Avatar
C320
Assuming the mechanical problem that caused the code in the first place has been fixed, yes.
Old May 12, 2017 | 08:10 PM
ItalianJoe1's Avatar
2003 CL 600
It should, yes.
You could try to disconnect the battery for a bit and see if it clears the TCM faults but that doesn't always work.
Old May 12, 2017 | 09:45 PM
mbismylife's Avatar
2002 Mercedes C230K
Thank you for the advice. I tried it out, disconnected for about 20 mins and then reconnected, but no luck.
Old May 12, 2017 | 09:46 PM
mbismylife's Avatar
2002 Mercedes C230K
I just ordered the scanner, will have it on Monday. Let's try doing that too.
Old May 12, 2017 | 09:47 PM
mbismylife's Avatar
2002 Mercedes C230K
Meanwhile any other advice/ suggestions/ tips???
Old May 16, 2017 | 12:11 AM
mbismylife's Avatar
2002 Mercedes C230K
You were so right... got the scanner, erased the codes and it started running perfectly... thanks a ton,
