Headliner removal
Old May 30, 2017 | 12:25 AM
Outlawlatemodel's Avatar
2006 c230
Headliner removal
Hi does anyone know how to remove a 203 headliner and will a c280 headliner fit, Thanks guys, Kevin
Old May 30, 2017 | 09:16 AM
BF_JC230's Avatar
2005 w203 C230
I would search.
There have been plenty of posts from water leaks, IMS install, to pre-face lift sag and re-line.
Some say to take out the back glass.
Others say to take out the center console and go from there. That is the way my WIS CD shows it - and it even states a fold will occur...it is normal and will not be noticed when finished.
To that end, I would get your hands on a WIS CD.
I would NOT try and fit your 1998 C43 with a w203 C280 unit...otherwise, we can not be sure by what you wrote what the other w203 is.
Good luck. Add IMS.
https://mbworld.org/forums/c-class-w...s-install.html
https://mbworld.org/forums/c-class-w...headliner.html
https://mbworld.org/forums/c36-amg-c...headliner.html
https://mbworld.org/forums/c-class-w...r-sunroof.html
Old May 30, 2017 | 10:31 PM
2006 c230
c43 has left the building
Hi My c43 is gone I am trying to figure out if a c280 headliner will fit my c230, Thanks for your time, Kevin
Old May 31, 2017 | 09:15 AM
BF_JC230's Avatar
2005 w203 C230
I would get into EPC and just check part numbers...
I would highly doubt that it wouldn't fit...that seems like a staple, large cost item that they would want to keep the same (sans trim/finish) across all models. The only part deviation I can think of would be for post op in handle, IMS, etc. cut outs...
May I ask why you need to swap out?
Old May 31, 2017 | 08:51 PM
2006 c230
water damage
Th windshield pillars and roof have water damage, pretty sure it will fit
Old Jun 2, 2017 | 09:39 AM
BF_JC230's Avatar
2005 w203 C230
Look into the TSB and Butyl Chord if applicable.
Also, I know there is an older post (I think from Japan or China) about a failing/rusting metal "U/J" union to the drain.
I am sure you'll want to fix the problem before you install the new headliner.
Old Jun 4, 2017 | 01:55 AM
2006 c230
I gotta find a way to get the smell out. Kevin Stewart
