Full gut and headliner
The seat belts were quite dirty. Cleaned up nice though. IDK how they got that bad. Only had the car a few days so some grungy stuff had to come out.
Can I ask WHY you removed the headliner - sag / smoke smell / dirt?
(Would have been a GREAT time to install IMS...BTW)
How did you remove it and install it - rear door?
- It looks like you left the rear deck / package tray and C pillar cover in - if you DID remove them - any tips or tricks?
- Any tips or tricks on the A and B pillar covers? Just pull and unsnap?
Great work - looks nice / clean and fresh!
What material did you use on the headliner, and where did you get it from? Did you use Super 77 for adhesive, or something else?
Headliner was sagging but it's impossible to reuse the old fabric due to foam under the material and glue disintegrated.
Pillars pressure washed nicely. If you do use very light pressure or you'll blow the glue off.
Carpets pressure washed very nicely considering how light in color they are. The sunroof tray won't come off unless you drop the entire cartridge off the ceiling and disassemble it so plan on re-doing that while it is still in the car if anyone tries it.
Everything I did for removal was easily found google searching before I started. It's a long process in this car. More painful than most.
