Replacing Headliner
Old Jul 28, 2009 | 07:59 PM
SparksterC43's Avatar
2008 ML320cdi, 2008 SL600Renntech, 2009 C63
Replacing Headliner
I have the new one. what is involved in r&R?
Any help would be appreciated.
Jay
Old Jul 29, 2009 | 11:12 PM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
To replace the headliner you will need to remove the front or rear windscreen (unless you have a wagon). If you don't then you will get a large crease mark down the head liner since you would have to bend it to get it in.
To get the head liner out remove the grab handles, sunvisors, overhead control panel (front interior light), rear interior light, a, b and c pillar trims. then the head liner comes out. Don't take sort cuts by not removing trims, you will damage the new headliner.
Old Jul 30, 2009 | 07:44 PM
speedybenz's Avatar
AMG C43, 1999
With regard to the head liner, once it is removed do you have good access to the sunroof glass? I (And I am not crazy) would like to replace the glass with Lexan to reduce weight, or even remove the sunroof completely. I never use it and all it does is rattle at the trim ocvering at the front.
Would this be difficult to do?
Jeff
Old Jul 31, 2009 | 11:17 PM
Ausmbtech's Avatar
You can replace the sunroof glass at anytime, it's easy access. To remove the sunroof frame then you would need the headliner removed.
Old Aug 6, 2009 | 01:58 PM
anisamy1's Avatar
Mercedes AMG
Can we change the headliner without removing the screen?
Old Aug 8, 2009 | 10:08 PM
hcetzneb's Avatar
2004 Ran SRT-10,2007 S550,2016 E400c
The headliner can be removed with out removing the glass.... after the headliner is completely detached from the roof move the pass seat back and recline it all the way back.
It helps to rmove the rear seat cushion so you can recline it further. You can fit the headliner out the pass front door very easily. The c class is one of the easier ones to do because the headliner is not as wide...
Old Nov 23, 2009 | 10:26 PM
m3j0n's Avatar
W220 V12TT Land Yacht / W211 E55 Estate
any instructions on how to remove the headliner? doing mine now
Old Nov 23, 2009 | 11:34 PM
m3j0n's Avatar
i have the damn thing completely off, but i cant get it out of the car! need some help asap. thanks.
Old Nov 24, 2009 | 01:10 AM
benthebenzguy's Avatar
1999 c43
out the passenger door, put both front seat backs all the way back, lower and turn out door
Old Nov 24, 2009 | 04:18 PM
m3j0n's Avatar
finally got it done last night. and removed the sunroof cover as well. Going to get it recovered and put it back in. thanks for the tip. BTW< the original glue is some NASTY ****.
Old Nov 26, 2009 | 08:33 PM
luiritrfgy's Avatar
yamaha
I accept with information:It helps to rmove the rear seat cushion so you can recline it further. You can fit the headliner out the pass front door very easily. The c class is one of the easier ones to do because the headliner is not as wide.
Old Nov 27, 2009 | 11:21 PM
m3j0n's Avatar
yep, i removed the rear seat and it was easy to take out. now i need to figure out how to get all this nasty glue off.
Old Nov 28, 2009 | 01:49 AM
PJmak's Avatar
Jeff
found this on youtube
http://www.youtube.com/watch?v=DQuB-...eature=channel
Old Nov 28, 2009 | 11:57 PM
tex07's Avatar
2000 C230 sport
how do you remove the interior c-pillar trim?
Old Dec 4, 2009 | 03:54 AM
m3j0n's Avatar
I have a question for those of you that did the job (removal and reinstall). Im having some issues now that I am installing the finished headliner:
a) the car wont start - im thinking something crucial may have been unplugged and not allowing the car to start?
b)the dome lights will not turn on, but the sunroof works perfectly.
c) there is one loose connector. I am not sure if this was connected when I took the headliner off, but I can say that I have no clue where it is supposed to go. I have attached some pictures. The connector is relatively small with a blue and brown wire.
larger pics available upon request. I originally thought I had found the location for the connector (marked with the green arrow), but it turns out that the connector does not fit there and there is only 1 pin.
Old Dec 4, 2009 | 03:58 AM
m3j0n's Avatar
I yanked, twisted and tilted trim while pulling it. It was FRUSTRATING to say the least... THose clips are VERY strong
Old Dec 4, 2009 | 06:52 PM
m3j0n's Avatar
anyone?
Old Dec 8, 2009 | 11:31 PM
m3j0n's Avatar
what is the recommended method for getting this G-Damn rearview mirron back in!?>!?!?!!??!?!
