2003 mb c240 a/c problems
Old Jun 14, 2017 | 08:59 PM
handydennis's Avatar
2003 c240 base
please help I have a 2003 c240 base
I brought a brand new a/c compressor and a/c temperature switch a nothing still blows hot air the clutch is spinning what els is there to do
Old Jun 15, 2017 | 02:27 AM
akssdd's Avatar
2006 C230 Sport Sedan
I have a number of questions.
After you installed the new parts to you put any refrigerant in the system?
Are you sure the compressor was your problem?
Did you check for leaks?
Also, if you did in fact have a failed compressor, it could of also damaged or clogged your condenser. And typically when stuff like that fails it's good practice to flush all the lines and evaporator before replacing the condenser and compressor.
