How to remove the sump
Old Jul 3, 2017 | 03:19 PM
Nevergiveup's Avatar
Mercedes C220 CDI classic SE estate 2002
I have a 2002 C220 estate with a 611 engine. I need to change a damaged piston. In order to do this the sump has to come off. The Haynes manual tells me to first lower the front suspension crossmember.(See chapter 10) however no mention of this part is in chapter 10. How do I do this? Can anyone help me with this information?
Old Jul 4, 2017 | 07:15 AM
playfair's Avatar
S203
hope this helps
Attached Thumbnails How to remove the sump-1.jpg   How to remove the sump-2.jpg   How to remove the sump-3.jpg   How to remove the sump-4.jpg   How to remove the sump-5.jpg
How to remove the sump-6.jpg   How to remove the sump-7.jpg   How to remove the sump-8.jpg   How to remove the sump-9.jpg   How to remove the sump-10.jpg
Old Jul 8, 2017 | 10:53 PM
Smile Thankyou for your help
Yesterday a friend and I using his engine crane managed to remove the sump, replace the damaged piston and re install the sump using a new gasket with sealent. I just have to re fit the cylinder head and put the engine back together. The info put on this post by Playfair was excellent. Thankyou.
Old Jul 9, 2017 | 06:14 AM
playfair's Avatar
S203
you're welcome. if it's not too late maybe you can post some photos as this can help others.
