Can any one do a burn out on the C230?
2003+ Mercedes-Benz W203 Dyno Mode Tutorial - YouTube
Turn key to position 1
Make sure screen shows any other display but mileage, otherwise it will reset trip odometer. If you don't care, go on to the following step.
Press and hold the reset button for 45 seconds (it will beep when read)
Turn key to position 2
Press bottom left button on steering wheel (the two pages one that sits lower than the other)
It will then show you software version, oil level, engine model, etc
Press volume up and it will show you the above option.
I personally wouldn't do a burnout in these cars, they are just too expensive to fix should something break. Maybe with some very old tires, but even then...
In my old Charger? Did it all the time without a care in the world.
I bought old tires .. And I have another problem... My display doesn´t show the miles traveled
That Happend
This is not going to be Fun at the track. Because i like to do a burn out and get those tires sticky for the track. But now how do i do that.Last edited by ric_c320; Jan 2, 2015 at 02:33 AM.
