Anyone have Bixenon problems?
The halogen lamps use 55 watts on low beam. The xenon lamps use 35 watts. The front SAM is dectecting this difference, and reporting a warning because the car has not been set to xenon=present. You might need to pay your dealer for half an hour to get that set.
Canada has a DRL rule, but I am not sure how Canadian market cars acomplish that. My US based car can be set for DRL via the multi-function display, but my Asian based car does not have that menu choice.
DRL can be turned off and on via the steering wheel controls on one of the menus on my car. I am not sure how Canadien cars provide the low power daytime running lights with xenon lamps.
and you have the error msg because you don't have the xenon to begin with. You'll need to go to your dealer or whoever ur tech is that have the Star-Diagnostic to set the Xenon setting to "present" otherwise the error msg will always be there.
the xenon beam turn on when you use the high beam because it's Bi-xenon. The normal high beam and xenon are both used when you turn on the high beam.
i'll get this done asap. they probably wont be able to do it for a few days, i was told by steve3 not to run my car till this is fixed, what should i do? i mean, i cant not drive it, i need to get to work. should i turn it on to high beam at all times till it is fixed so it doesnt flicker?
yeah, thats true. it's b/c mine didnt come with it, and since the guy that installed it messedup and didnt set them to ON they're turning off. but what i'm wondering now is what i should do since i HAVE to drive it a few days before i get it fixed to avoid burning it out and blowing up the entire unit, should i turn it on high beam, would that avoid the flickering?.
i really just want to avoid damaging it till it is fixed. and ppl keep mentioning "flickering", do they mean this in literal terms or does the ignitor flicker on and off to keep it running?
Erik
so now i have to wait. i called my dealership and they wont touch it. at least they dont flicker, it just shuts off when it dectects light, i wonder if this will damage anything?
Good luck,
Erik
Hi,
I brought my vehicle to the dealer 2 wks ago, for a change of a headlamp--which wasn't working(no 'white light'). They decided to change both for me b/c the other one "was also checked & seemed to be about time". Two things I was told(after got off the phone w/ them--inquiring the lack of 'whiteness' of the lights): (1) It'll take about a wk for the lights to work properly...(2) The bulb/lights/whiteness will not be projecting the same as it was first came fr the manufacture. Are they true? If so, how do I get my headlamps(bi-xenon) to project their whiteness/intense purple-ish as it was before--when I first purchased it(brand new)? Would you please be kind to provide me some info on this?
This is second wk now--and the lights still not intense as they were once before. When I first start the engine--I can see the blue-ish-white lights(like it was originally before)...but after 20 or 30 seconds its intensity gone.
Thank-you so much for taking the time to read my message!
Have a pleasant day!
Kind regards,
Reynaldo
Driving the car during anytime of day WITH your canadian light settings and WITHOUT the xenon set to present WILL RUIN THE XENON HEADLIGHTS WITHIN A FEW DAYS!!!!
Switching the lights on before actually starting the car might work BUT IS NOT SAFE as the lights WILL switch off by themselves again AND YOU DO NOT WANT THAT TO HAPPEN IN THE MIDDLE OF THE NIGHT!
so in short: get the xenon set to present NOW (rather then ASAP as that is already too late).
greetingz,
greetingz,
why do you want to disable it? just curious.
i brought it to MB and they wont touch it, they said if they wired it correctly there is not reason why the DRL is off. and really that is teh only thing is wrong with the BIX at the moment, they dont flicker or anything and at night they stay on!
the guy from the shop that did the retrofit says his current software only handles up to 04 modles and he donest use star, but something equivalent to it, is this bull ****?
i cant find anyone that can help me in Vancouver! they either dont know what to do (dont have the software) or simply wont (MB).
this is so frustrating! i had no idea this would turn into such a nightmare, over 2 grand now and they dont work properly, and if i dont get them fixed soon they could damage all together.
I guess you need to find the "right" service advisor, try to bring some beers or something, my SA is very kind for me and always willing to help me....
