drivers side mirror question
i do know that it's auto dimming....
For LHD cars
Left hand, heated, aspheric, dimming A203 810 03 21
Right hand, heated, aspheric A203 810 02 21
For RHD cars
Left hand, heated, aspheric A203 810 01 21
Right hand, heated, aspheric, dimming, A203 810 04 21
These are direct replacements for the flat mirror glasses in US/Korea/Gulf-states. I beleive *all* mirror types are heated on the W203
Im told you can order them direct from your US dealers, dunno what it will cost you ...
The dimming mirror is about 4 times the cost of the non dimming mirrors. If you have a dimming mirror, I think you must replace it with a dimming mirror - the connectors the mirror glass on all the other MB's ive looked are different depending if they have dimming or not.
C class W203 european mirror (with aspheric blind spot mirror) part numbers
Do you know if these part numbers are the for dimming variety?
Also, they have two new options, one is a peel and stick ($7.50) and a Rearview mirror add-on ($30). If these are the same quality as their original mirrors, I will consider the rearview and whether its worth covering up the autodim feature (maybe the main mirror is removable)... Here's a link. The peel and stick is on the right edge.
Brookstone Stores
Thanks Richard!
If you have non-dimming on both sides, use the right hand mirror from the left-hand-drive and the left hand mirror from the right hand drive part numbers
Cheers
R
I sent this by pm but thought others might like instructions in case they ordered the Euro blind spot mirrors:
I received my Euro blind spot mirrors today - thank you for the part numbers (US C230K w/ auto dimming driver's side and nondimming on passenger)- and I was wondering if you have any specific instructions on how to install them --
Any assistance is appreciated.
Thank you
Jerry
If you push the bottom edge of the mirror glass in, so the top comes forward, you can see the metal clip that holds the mirror glass onto a plastic tab on the main mechanism by looking into the gap between the mirror glass and the body.
If you put a small hook like thing or a flat screwdriver in, you can pull up the metal clip upward and the mirror glass will drop forward and can be removed.
When you put the new glass in, look at the mirror glass carefully, and its possible to fix the clip "upward" over a little tab on the plastic bit of the mirror glass. (mine came with the metal clip in the right position for this) - This allows you to clip the new mirror glass in at the bottom first, then just move the metal clip slightly with a flat screwdriver and the clip will pop over that little tab into its "locked" position.
Its a lot more obvious if you are looking at a mirror glass
Cheers
Richard
I think that if you affix the blind spot mirrors during cold temperatures, they are likely to pop off when it warms up.
I just affixed 2 new ones in hot temperature, so we'll see if they stay on.
