C240 radiator fan connected to a/c system?
Good day ! Is the radiator fan connected to the a/c system ? Because my a/c compressor is due for replacement, is it the cause that the radiator fan not kicking in ?
I don't suspect a bad radiator fan or fan module because i pulled off the socket in the coolant temperature sensor and the fan turns on high speed but when i plug it back the radiator cooling fan stops
