No wipers, no AAC no dome lights (both SAM's already replaced)
Old Feb 8, 2018 | 10:15 AM
mmech89's Avatar
c180 c200 etc
Hy. Sorry to open yet another SAM thread, but I got them both replaced with exactly the same reference and to no avail.
Car is a 2001 C 180 CL203 VIN WDB2037351A122738 engine code M 111.951.
Like stated in the title wipers do not work - at all, i got no interior lights, AA/C command panel is dead (no lighting, no response), SRS indicator is ON(probably because of the ESP codes). There's the "display faulty" warning.
Fuses/relays have been checked- all ok. Battery is new and fully charged.There was a battery drain before (i will have to wait to see if it's still there) - car does not have power seats.
Everything else seems ok (lights, indicators, engine, etc)
Here are the codes I pulled from it :
Multifunction (SAM - Rear (Signal Acquisition and Control Module - Rear) -
SAMH203 (Signal Acquisition and Control Module - Rear) - MT/AT)
DTC Description
B1096 - Fault in CAN communication with control unit UCP. If fault code occurs with no
complaint reported and no malfunctions, erase fault memory and perform a
function check.
- Permanent
B1091 - Fault in CAN communication with control unit AAC pushbutton. If fault code
occurs with no complaint reported and no malfunctions, erase fault memory and
perform a function check.
- Permanent
B1090 - Fault in CAN communication with control unit OCP .If fault code occurs with no
function check
- Permanent
Multifunction (SAM - Front (Signal Acquisition and Control Module - Front ) -
SAMV203 (Signal Acquisition and Control Module - Front ) - MT/AT)
DTC Description
B1030 - Control module UCP is not transmitting any data.If fault code occurs with no
function check
- Permanent
B1029 - Control module AAC is not transmitting any data.If fault code occurs with no
function check
- Permanent
B1031 - Control module OCP is not transmitting any data.If fault code occurs with no
function check
- Permanent
Brake (ESP/BAS (Electronic Stability Program) - ESPMK25 (Electronic Stability
Program) - MT/AT)
DTC Description
C1010 - ESP and BAS control module; faulty
- Intermittent
C1140 - Steering angle sensor, plausibility
- Intermittent
C1141 - ESP brake pressure sensor; plausibilty error
- Intermittent
C1202 - BAS release switch; plausibility
- Intermittent
Any ideas ? Thanks.
Old Feb 8, 2018 | 04:42 PM
Russell Ormerod's Avatar
not a merc
Do you have communication with OCP UCP and AAC?
If not check there power supplies
