What's the payload in the trunk of a c230?
Old Mar 15, 2018 | 04:49 PM
scottonfire's Avatar
2013 c250
I'm hauling slate tile next week, need to know how much weight the trunk can handle.
Old Mar 15, 2018 | 06:26 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Slate? The real question is how many bodies?
Old Mar 16, 2018 | 02:50 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
It's in your manual.
Not sure about the sedan, but the coupe is rated at 100kg. I'm sure one can go over this number without damaging the trunk, though I would personally reinforce the flooring (for example using a sheet of plywood) first.
Old Mar 16, 2018 | 08:28 AM
BF_JC230's Avatar
2005 w203 C230
What about just renting a pick up truck from the Big Box (or a close to where you're buying the slate) home improvement store?
Old Mar 16, 2018 | 02:07 PM
2013 c250
it's 90 miles away.
100KG is like 220lbs. Great so I can take 35 pieces of slate only needing to take 3 more trips to complete ONE ROOM.
Old Mar 18, 2018 | 09:52 AM
efzauner's Avatar
2005 C240 2011 R350
you need an R350 with self leveling rear suspension.. I think I took on 1500lbs of vinyl flooring once.
Old Mar 18, 2018 | 11:08 AM
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
since the panel that makes up the trunk floor is only about a quarter of an inch at most, I would not recommend no more than a hundred pounds or so. I damaged my trunk floor panel before because of putting too much weight there. Also, the rear suspension will probably bottom out with all the slate back there
Old Mar 19, 2018 | 09:54 AM
efzauner's Avatar
2005 C240 2011 R350
That's why the wife gets a minivan....
Old Mar 20, 2018 | 05:05 PM
Used to haul my bass amp, sound system, instruments etc.
Totally hosed the trunk, had to replace all the pieces and then put plywood down.
It's all plastic.
Old Mar 20, 2018 | 05:30 PM
Jay11's Avatar
2003 Benz C240
Why not install a hitch (about $250) and buy harbor freight trailer. I bought the small 4x4ft and stretched it with an angle iron to about 7 ft, works great.
