C Class Command question.....?
Old Apr 15, 2002 | 03:49 PM
Silver_Lana's Avatar
Does anyone who has command on their C Class know if we get this Auxillary input too?
https://mbworld.org/forums/showthrea...&threadid=6052
Thanks!
Old Apr 15, 2002 | 04:13 PM
Lynn's Avatar
I don't have COMAND, but for those who do there is an AUX connection in the glovebox.
Old Apr 15, 2002 | 04:49 PM
thanks for the reply....
do you know if its still there even if you have the CD Changer installed in the glovebox?
Old Apr 15, 2002 | 05:25 PM
Lynn's Avatar
It should be. The changer doesn't use the AUX connector. It has a separate fiber optic cable.
Old Apr 15, 2002 | 05:49 PM
slcvr6's Avatar
Awaiting a new arrival...
I have COMAND in my new C230 and the factory changer in the glove box and I DO have the auxilary input, as well.
Old Apr 15, 2002 | 07:58 PM
cool....
thanks for the answers guys!!!
I am taking delivery of my C 320 with Command, V 60 Phone with Voice control and CD Changer in about 6 days... just wanted to know if i could hook up my MP3 player (iPod) through that...
Old Apr 15, 2002 | 08:00 PM
i better update my profile..... or sig..
Old Oct 21, 2002 | 07:36 PM
Geo's Avatar
Geo
c230 coupe
command auxillary
where is the aux input for command in c230 2002? I also have a CD changer. Can I find it myself or do I need someone else to hook it up for me. Thanx
Old Oct 21, 2002 | 08:01 PM
slcvr6's Avatar
Re: command auxillary
Look in your glove box, all the way against the right side...see that small silver hole, thats it. You can't miss it. To activate it, you must hit the SVC button and choose the AUX option on the COMAND unit.
Old Feb 8, 2006 | 11:39 AM
morph860's Avatar
2013 C300 Sport 4Matic
Do all cars have this? My car came stock with the CM1010 and 6 cd changer. I installed a COMAND 2.0. Will I still have this AUX input? Which cable would I need to buy?
Old Feb 8, 2006 | 03:20 PM
Buellwinkle's Avatar
If you installed your own comand then it's easy. I cut off cheap headphones leaving a about an 18" long wire with the correct plug that works in my iPod. Then tap into the C2 connector on the back of Comand and I ran it under the unit and into my ashtray where I keep my iPod. The wiring diagram is somewhere on my website in the Comand WIS. You activate is from the radio side by pressing the SVC button and navigating to AUX and setting your sound options. If you have a U.S. spec Comand, you get the pleasure of setting sound settings each time you start your car.
Old Feb 11, 2006 | 05:06 PM
morph860's Avatar
When you did this, did you only wire in the AUX LEFT and AUX RIGHT pins? Or did you need something else for the AUX SHIELD? I am getting ready to do this as well, just making sure I have everything I need before I start. I have my headphones cut already, with the 1/8'' connector on one end, and the wires at the other. Doesn't look very hard. Did you order the connector pins from MB? I'm sure they sell them other places too right? Maybe Home Depot? Thanks
Old Feb 11, 2006 | 07:58 PM
JeT's Avatar
JeT
If you are not a cheap-*** you can get the correct Aux input cable from MB. Check this thread for the correct part number...https://mbworld.org/forums/showthrea...2A+part+number
Old Feb 11, 2006 | 08:08 PM
morph860's Avatar
Thanks for the input, but cheap has nothing to do with it. I have all of the parts I need here at home already...why would I go buy something from the dealer?
Old Mar 30, 2006 | 01:26 AM
bhwbhw's Avatar
Aux for 2003 C230 Coupe
My car has the punch-out circle in the glove but I'm not sure if the aux (part number: 203-540-61-07) will work or have that already installed white connector. Could some one please let me know if that's the right one and if not, how I can get one installed?
