Limp Mode
Old Apr 24, 2018 | 01:49 AM
Louis Rossouw's Avatar
2006 C220 CDI
Limp Mode
My 2006 C 220 CDI goes into limp mode all the time with the orange engine light coming on. Turbo was replaces as well as the pressure and air sensors. Problem persisted. Then had the master air sensor component replaced still the same problem. If I stop and restart car goes back to normal for a short while but then back into limp mode. I am so tired of this and this problem just don't seem to be solved. Had full diagnostics done. Only fault shown by MB diagnostics is "LOW AIR PRESSURE". There are no pipes leaking air, sensors replaced so what now?
Old Apr 24, 2018 | 04:30 PM
Russell Ormerod's Avatar
not a merc
Where in SA are you?
Old Apr 25, 2018 | 01:48 AM
2006 C220 CDI
Limp Mode
Hi Russel,
I am in JHB
Old Apr 25, 2018 | 03:28 PM
not a merc
Okay, I am in CT. Check those boost pipes carefully, they like to split and only leak under boost,
