Need help locating Fiber Optic cable for CD changer
Help! I can't find the Fiber Optic cable in my trunk!
I have a 2002 C32 that doesn't have the CD changer and show no signs of ever having one installed before. I got the original Mercedes CD changer model MC3010. I looked online for tutorials and all of them go into quite a bit of detail regarding taking apart the vents and removing the head unit, however none mention anything about the Fiber Optic cable other than "it's in the trunk".
Well, I opened my trunk, looked for it and only found some cables underneath a plastic shield held together by two torx bolts that hold down the plastic shield and two metal swivel anchors.
Underneath this shield, I saw a bunch of wires and a black motorola box. In this bunch of wires, I saw what looked like the same fiber optic cable in other people's tutorials. It was orange, had one end with a connector with a cap on it and was held on by 3 zip ties through it's length to a bunch of wires. I followed the cable to find the other end but couldn't find the other end. As I followed the cable, it seemed to go up into and behind a carpeted cover/panel near the rear passenger side of the car. I tried to take this panel off and only took part of it off since it covers the entire passenger side of the trunk. Anyhow, as I lifted the panel off to one side, I noticed the orange wire was going straight up. Before I went any further (plus it was dark outside), I wanted to consult all of you who have installed a CD Changer before in a W203 C class sedan w/ Bose and help me locate the fiber optic cable.
I would like to do a tutorial with detailed pics b/c seems that there isn't one out there. As long as I get some help locating the fiber optic cable, I should be okay and can complete the rest. Can anyone help?
Thanks!!!
-s-
http://home.earthlink.net/~phdwebsit..._bulletins.htm
Select your model/year. Note how that the W203 CD parts list includes the required fibre optic cable.
-s-
Now my dillemma is finding the CD changer power cable as I've looked high and low in the dash and didn't find anything behind my Navigation system.
Can anyone be kind enough to send me a picture of what the Power Plug looks like? All I found that was a close match was a black 3 wire ribbon cable with a plug on it (this plug was in the middle of the cable, not the end) and it originally was plugged into the climate control. I tried it and it didn't turn the CD changer on and also caused my stereo to produce no sound (probably b/c the changer wasn't on and couldn't send the fiber optic signal through the loop). Can anyone help? This is taking much longer than I had anticipated.
If anyone's in the Bay area (SF) and wouldn't mind testing my CD changer for me in their car or helping out with the install, I'd really appreciate it.
Thanks!
Benny
The power connector looks pretty much the shape as the one that goes in to the climate control (please leave that one in the climate control) except it has discrete wires going into it, that are usually colored.
Oh, it's usually taped with masking tape or something. Look for that.
-s-
I posted photos of the entire Cd installation, all parts and tools needed. Also photos of the power plug and where it is located.
For people looking at this thread in the future, I used the spare Fiber optic cable from the trunk with SPS In and SPS Out tags. The Power cable is behind the head unit but tucked away near the passenger footwell. It's multicolored and is wrapped once in masking tape. You'll have to put your fingers in there and dig for it b/c you can't see it b/c it's hidden.
-s-
If you want more details, PM me for the document.
