New battery failed in 8 days
Old Jun 1, 2018 | 01:12 PM
Russell Ormerod's Avatar
not a merc
You not understanding the problem! It's plain to see, term 15 present term15r not present! A condition that should never occur. So now you want to mess with SRS, which has nothing to do with the fault. If you think you know what you doing don't mess with SRS module! There are very specific ways to work and test SRS systems. Have you ever been punched in the face with an airbag? Leave it alone!
I am telling you to test that SAM properly, check the light inputs, check why it says light fault, the SAM generates term 15r and 15. I have worked on hundreds of These cars and by your explanations my first stop will be front SAM!
Good luck
Old Jun 1, 2018 | 10:31 PM
KevinH2000's Avatar
2005 C230 Sport Sedan-6 Speed Manual
Got it. And thanks for the warning on the air bag.
Sorry to be so slow in understanding the MB. I'm accustomed to working on less complex cars.
Old Jun 2, 2018 | 07:02 AM
not a merc
No worries, what is the part number of your front Sam?
Post a screen shot of your actual values when your light switch is off
Old Jun 2, 2018 | 02:48 PM
KevinH2000's Avatar
Light switch message
I am going to be away from the car for a few days. I’ll post the SAM information when I return.
Old Jun 2, 2018 | 03:30 PM
not a merc
Okay, you need to see why its at fault status, must be a voltage value that's incorrect or not seen correctly by the front sam
Old Jun 17, 2018 | 09:21 AM
KevinH2000's Avatar
I just returned from my trip and I am picking up where I left off.
I'm not sure where to find the part number of the front SAM. Based on this photo, it appears to be AMP 1-929 227-1, but I may not be looking in the right spot.
One of the responses I received on Benzworld: http://www.benzworld.org/forums/w203...rs-help-6.html indicated that a damaged M Terminal 15R relay could be causing the problem. I am planning to try the test he suggested. The relay seemed to be firmly seated. It looks fine, but internal damage isn't visible. Although I dislike throwing parts at a problem, it is relatively inexpensive to replace the relay. The part number for the relay is A 002 542 26 19. I have some Father's Day activities to attend, so I may not be able to work on this today. When I do, I will take some screen shots of the actual values.
Thanks again.
Old Jun 17, 2018 | 02:01 PM
  #32
contact148's Avatar
2003 c240 4matic wagon
if the same relay is used somewhere else on the car just swap them if the problem moves you know its the relay
