Stock radio not working: OFF
Mercedes Benz Sportcoupé CDI 220 year 2002. Mod. 203.706 143cv
How can i solve this problem?
There is some fuse to change and which one?
Thank you
Thank you
The #36 i cannot locate on my car because i have not in my hands the correct diagram for the inner fuse box (near the steering wheel) of the car. And so when i open the box i don't know where is the 36 or if it's present or not.
I have another fuse diagram which is different from the inner box in my car.
I would like to find the correct fuse diagram for that box. I have the other 2 diagrams but not the one i would like to have for the radio issue.
Regards
If you take a flash light you can see very small numbers next to the corresponding fuse. There might be some that aren't numbered depending on the options in your vehicle but they will still follow the numbered path to the ones that are.
Thank you mate but the fuse diagram i have in my hands is different from what i see on my car, i miss that one, so i can't know where to insert an eventual fuse... paths maybe are differents.
That's why im looking for the fuse diagram left steering wheel proper of my car.
That's what I'm saying. You don't need the diagram if you can see the tiny numbers. If it does not match the car it is kind of useless. The numbers will be on the fuse area itself, usually on the right side I think. Very small numbers but they are there in each fuse area.
hEEk (05-04-2018)
I will do a diagnose with star diagnosis
