2005 C240 4MATIC, is an alignment possible on a 4matic?
Old Jun 23, 2018 | 07:15 PM
awbooth's Avatar
2013 Mercedes benz ML350 4Matic
Just replaced the large "wishbone" control arm which consists of 2 large bushing connections on one side and a ball joint on the other. The issue I have now that I resolved my clunking-bong noise by replacing the 4matic control arm... the steering wheel is off and the alignment seems to be bit off... anything I can do to re-align? I've been told you cant do a legitimate alignment on a 4matic... thx guys!
Old Jun 24, 2018 | 06:06 AM
awbooth's Avatar
Thx for the info
Old Jun 26, 2018 | 05:48 PM
contact148's Avatar
2003 c240 4matic wagon
yes you can have it done I had it done 3 times replaced both lower control arms and a rear suspension part I cant recall
Old Jun 29, 2018 | 09:23 AM
Nektopoli's Avatar
W203 & W204 3.0L 4matics & MR2 Supercharger
I just did the right side along with the tie-rod end, drop link and CV half shaft, the alignment was off so I just adjust the tie rod end (13mm & 21mm open end wrench needed) until it was close. I true alignment will be needed. What people are talking about is there is no precise camber adjustment available, just a set of new bolts that allow +/-3.4 degrees of camber depending on how you bolt the arm to the carrier (the adjustment bolts are slotted and the carrier has pins that these slots slide into.) - NP
Old Jun 29, 2018 | 06:19 PM
awbooth's Avatar
Ok, thx!!
Old Aug 12, 2018 | 12:34 AM
jvakos's Avatar
E63 SL55 996TT C5Z06
Awbooth - what issues or noises were you getting with your front suspension that led you to finding the control arm and ball joint was bad? i have a 2004 c240 4matic with 118k and have some bad front end rattling and loose steering going on. will be replacing the outer tie rods but dont know how to tell if my control arms are bad???? thx in advance
Old Aug 12, 2018 | 07:13 AM
awbooth's Avatar
We were getting a strange noise coming from the drivers side when entering our driveway. The 4matic has different front end suspension parts so take caution when ordering, good luck!
