Mr
Old Aug 26, 2018 | 03:04 AM
Nhlaka's Avatar
Mercedes C350 2007 Model
Mr
Hi
i have a problem with my Mercedes C350 fuel gauge, I had changed the petrol pump then after 2days I've changed it my fuel gauge just dropped to empty but the orange light never came on then I refill at the petrol station the gauge still never went up. I now have the tank open wanna see or know the problem and I'm stuck. Please help
Old Aug 26, 2018 | 12:55 PM
Russell Ormerod's Avatar
not a merc
You need diagnostics then read the values from the rear sam
Old Aug 29, 2018 | 01:58 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
What kind of title is that, Mr?
I'd say if your fuel level worked on the old pump and since you put the new pump in it now it doesn't work, . I would say that the problem is in the new fuel pump as that is where the float is.
Since you have the tank open, put the old pump back in plug it in, turn the ignition to the second Notch and see if it registerd fuel. If it does you have your answer. I'm guessing you didn't buy a genuine Mercedes fuel pump?
