Passenger headlight only works when the car is OFF. Flickers and fails when car is on
Old Nov 7, 2018 | 08:03 AM
Stuka Bomber's Avatar
2007 c280
I've never seen anything like this before. For a couple weeks my passenger side low beam has been flickering and turning off. Ordered new bulbs and installed them last night. While installing them I turned them on with the car off and they worked just fine. Later in the evening I go to take a drive and upon starting, the same headlight flickers and turns off when the car is on and I turn on the low beams. If i turn off the headlight, and turn them back on the same thing happens, turns on, flickers, and dies in 5 seconds.
So I turn the car off, turn the headlights ON and both work fine for as long as the car is not started. With the headlights on as I start the car both beams will remain on for about 30 seconds. Then the passenger low beam flickers and dies again.
Im clueless here. To me, its a relay issue or the headlight switch itself.
Any ideas here guys?
2007 C280 4MATIC
Thanks!
Old Nov 8, 2018 | 08:51 PM
Audi Junkie's Avatar
E Coupe C207, ML W166, ML W164, Sprinter 1500/144, W111 SB220 Fintail(s), A5 chassis Beetle 5+5
Inspect the wiring inside the headlamp housing. It's biodegradable wiring harness, and decays rapidly, allowing for shorts. Mine are bad, but don't short atm. I'm considering using some liquid electrical tape on them, but might get new ones.
Old Nov 10, 2018 | 08:57 AM
Mercedes_hate's Avatar
C230 K
Ground issue. Follow the wiring along the fenders and find the common ground. Should be a 10mm nut, you'll likely find it loose. If so tighten and it'll probably fix your issue. The car running is vibrating enough to make the difference in a good connection and not. If that doesn't work, I'd do as Audi Junkie said and make sure the wires in and outside the housing are not shorting by touching bare wires. The wiring has always been horrible in these areas. The rubber disintegrates leaving bare wires to short and cause all kinds of gremlins.
Old Nov 14, 2018 | 08:13 AM
2007 c280
awesome, thanks for the tips guys! Ill do these suggestions tonight!
Old Aug 27, 2022 | 01:59 PM
GrandPrix's Avatar
C230 SC 2002 White 1992 Toyota Hilux 225,000 miles, 2017 Subaru STI
The wiring insulation in both my headlights has disintegrated. It’s unbelievable how brittle these cars have become. My 30 year old Toyota is pristine with little upkeep. Sorry, but wire insulation should not just disappear into fairy dust. Damn fire hazard.
Old Aug 27, 2022 | 02:35 PM
slammer111's Avatar
2003 C230K Coupe Orion Blue
Just curious, did anything happen to the wiring beforehand?
The stuff in my headlights is still basically brand new. So is all the harness wiring, despite being splattered with oil and other fluids over the years.
Old Sep 2, 2022 | 05:27 PM
GrandPrix's Avatar
No. Car has been mostly garage kept since I got it. The plastics and rubber have turned into sand. The wiring insulation is now perished. Might be a for sale sign on it soon. About 88000 miles. Mechanicals are not problematic. 6 speed manual.
Old Dec 3, 2022 | 03:04 AM
tkid's Avatar
C230K M271 CL203 2003 model
Hi GrandPrix, Do you live in an extreme climate area? Freezing or very high temps?..
my wiring looks solid for now, but i maybe lucky to live in a moderate climate area, with mild winters, and not too hot summers..?
