Immediate help please!!!
Old Dec 14, 2018 | 10:11 AM
Paul Price's Avatar
2005 E500 rwd, 2004 E320 4matic
W203 will not start!!
I have a 2007 w203 4matic. Bought it cheap I have had to repair the infamous intake manifold repair.
I did that last night replaces parts with aluminum upgrade.
But I'm still having same problem I'm have alot off false starts. It will turn over trying to start but just will not do it. I have to open driver window close door reach in turn the key and run to engine and shake the control module thats in the middle of the engine cover to make it start. The control module was replaced before I got it. Its newer than the car itself.
I have checked my ME 9.7 coding and variant and it says all but 1 is correct. Can anybody tell me how to fix this what coding goes for my w203.
my vin # is WDBRF92H17F912588
When I pull frpm list to select the unknown variant coding it's a list that says HM0375 and goes up to HM0562.
Main questions if I fix this variant code will it fix my false start issue,
and if not what am I missing to make this car work right. I did notice the ME 9.7 That is on the car is newer than the car itself so someone has changed that but one variant code is unknown.
my star c4 is not showing any faults or areaor that I need to check or fix!!
Old Oct 22, 2021 | 04:38 PM
NOSBandit's Avatar
ml350cdi and clk280
hi, I was just wondering if you managed to find out about those HM variant codes
Old Oct 23, 2021 | 05:37 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
If all else fails, unfortunately you're looking at the dealer. They will know what firmware goes into the modules, and can upgrade you to the latest versions.
Old Oct 23, 2021 | 06:41 PM
Russell Ormerod's Avatar
not a merc
You looking in the wrong place. Variant coding will not cause your issue! What you see on das is normal. Have you checked fuel pressure?
Old Oct 23, 2021 | 06:42 PM
not a merc
