REAR RUBBING (17'*8 + 20 mm H&R Spacers).
I have installed the brabus monoblock VI rear with 225/45 offset et30 with 20mm H&R spacers, and I have some times rubbing.
Tomorow I will take pictures, but I supose ocasional rubbing is very bad and will take out the spacers.
Do you know if H&R 10mm or 15mm will have enough clear area?
Best Regards.
Ruben.
Hello,
Best Regards.
Ruben.
I've no rubbing problem with the either fenders or shocks.
Regards
I have 18x8 with 15 mm spacers... works fine no rubbing in the rear, and 18x8 with 19mm spacers in the fronts...
225/40 all around
wow! i think 10mm spacers should do the trick. im thinking about getting 5mm spacers for my front when i get the 05 brakes put on my car.
So did goin without spacers solved your rubbing problem?
Best Regards.
