2006 w203 Alarm Issue
Old Oct 8, 2019 | 10:13 PM
redsox3308's Avatar
2006 c230
I have a huge problem. I have replaced my dead battery in my 2006 c230. I connected positive first and then to the negative. When I do, all hell breaks loose! Headlights come on, horn starts blaring, wipers start, and the window wash starts spraying. I can't move the vehicle the brakes appear to be locked. I can't seem to get into my trunk to access the fuse box. I know that going to the dealer will be a couple of thousand. Even though it only has 53,000 miles and is in wonderful condition, I would have to let it go. Does anyone have any fixes or ideas to help? I really love that car but my wife is now referring to it as "the lawn ornament".
Old Oct 9, 2019 | 08:51 AM
Russell Ormerod's Avatar
not a merc
Did you try jump starting it before you replaced the battery?
Either way it sounds like you are going to need a new Front SAM
The front SAM controls all the items you mention!
Good luck
Old Oct 9, 2019 | 11:03 AM
redsox3308's Avatar
2006 c230
If I order the SAM, can I replace it myself? I would really like to avoid going to the dealer. The closest dealer is 100 miles away (I live in rural Maine) and the costs could soon get out of hand. I really appreciate all the help. It's been in this state for over a year and the wife is getting impatient.
Old Oct 9, 2019 | 03:23 PM
not a merc
You can change it yourself yes! There are many electrical plugs under the sam, so work carefully.
Old Oct 10, 2019 | 12:07 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
You can also swap in a used SAM. Just get one from a car of the same year, model and options as your so no coding will be needed.
