Radio CD for Mercedes C240 2003
I just bought A mercedes C240 2003 and has Only old cassette syetem with no CD ... Is there any Mercedes Radio that has a CD on Ebay for this model please ?
Any suggestions will be really appreciated
Here is my Loverly mercedes 133 000 km -
I Also need to know how to install a New CD Changer ... where I can find the wiring to Add it ? Thanks
My Radio has a CD button but i have a message that i Need a CD changer
The car (the North American ones at least) comes pre-wired with the 3-pin power cable for the changer. I bought my changer off a guy who included the required (2) fibre cables. If your car has nothing else in the loop (voice control, Tele-Aid etc.) then it's a very simple addition as the fibre simply has to go between the head unit (radio) and changer in both directions. I assume you don't have any of those other modules in your vehicle.
Any connector pieces for the fibre loop can be picked up at the dealer, though you shouldn't need any.
There's no reason why the Alpine unit shouldn't work. However you'll probably have to redo the speaker connections. Whether or not the steering wheel buttons work is a totally different matter. Supposedly some exist out there but the Alpine would need to support this as well.
1. Details to Add mercedes CD Changer
2.Install a Different Radio brand
Am I Correct ?
If/when you find one and remove it, you’ll see how it goes back in. In general, the harnesses for these cars usually include the wiring for optional accessories.
I have one but don’t use it much any more. What I’d really like is an inexpensive audio AUX. The facelift cars (>2005) only need a cable running from the wiring chase under the passenger door sill to the glovebox. I wish there was something like this for pre-facelift.
5
I tried to figure out if I have already a prewired for my CD changer in the back of my radio and here is what I have ( see comment on the bottom of each photo ) .... please help
I have the orange fiber wire connected to my radio but i can find where it goes to connect the other side to the cd changer , unless I need another Fiber cable to Add it as an extension
I tried to follow to orange wire to see where it goes but couldn'T , is it normal ? do you think it s already connected somewhere Or I can just pull it out and connect it to the cd changer
I couldn't find where the power cable has to be connected behind the radio what do you think
If not, it's a very simple installation. Just make the 2 orange (fibre optic) lines run between the the radio and CD changer. I do remember the existing orange lines coming out of the back of the radio doing almost nothing useful. Iirc they just terminated somewhere nearby and they put an end cap on it.
If the fibre connectors are incorrect (straight vs 90 degree etc) or you need need to join (end to end splice) 2 lines, the dealer has all the required connectors for a few bucks. Every length of fibre has a red end and a white end. In other words, the red end of a fibre line coming out of radio should connect as a white end at the CD changer.
As a tip, the weird rectangular tube once you cut open the glove box hole simply curves downwards and opens up into the space behind the radio. Route your fibre lines through there.
As for the 3 pin CDC power connector, I found mine wrapped up (strip of felt tape) along one of the cables that fed into the radio. Just dig around once the radio is removed. I'm pretty sure your car would have this. Unbundle it then feed it through the same rectangular tube into the glove box.
So since I already Have the orange cable behind my radio, this means that What I Need is this :
https://www.ebay.com/itm/Brand-New-C...97.m4902.l9144
If so, what about the Power Wire behind the CD changer ( see picture in my last Post ) ? do you know if it has to be pluged in the back of the radio too or somewhere else ?
Thanks a lot
The power cable behind the radio needs to be unwrapped then fed through that rectangular tube (goes into the glove box) then into the back of your CD changer. It goes into the plug "A" in your photo. It's already powered, as prewired from the factory.
Has your radio wiring been hacked? I see electrical tape that shouldn't be there.
My radio was not hacked as i Know ...
, so I Am at 50% of the problem solved , Thanks 100000000 times .Now , what I did for the Fiber wire that I never found where it goes , I Open the trunk compartiment and I Found 3 Orange fiber cables that are not plugued anywhere ( see pictures ). please tell me which one I can use to connect directly to the CDC. ( when you see the pictures, please tell me also where the Audio Amplifier is located )
The last 2 photos are the power and antenna and fibre connections for the (way obsolete) V60 cell phone option, which your car doesn't have. There is an aftermarket Bluetooth puck that works the same way and is compatible with your stock radio, called the Argos MB-1 by Eiskits. I think the company went under, so if you want this thing you'll have to look on eBay. I have this puck installed and it does the job but the stock microphone in the car (tucked up in the vent in front of the mirror) is a bit lacking.
For now, simply attach the fibre lines from the CD changer to the radio using the small loop you have. Follow the fibre lines currently plugged into the radio and you may find some of them actually terminate at a splice a short distance (talking 0.3m or so) away. In any case, open up the plastic plugs (the black trapezoidal pieces, not the white/red fibre ends) and create a fibre loop between the CDC and radio. The white end from the radio goes into the red end of the CDC, and vice versa. Shine a flashlight into the end of the cable to make sure you have the correct piece in your hand before reassembling the connectors.
I remember I needed a (1) fibre end-to-end connector to properly join 2 lengths of cable to join the existing line to the CDC fibre harness. Picked one up at the dealership for a few bucks.
. 1 . See picture 1
2 . See Picture 2
3 . Where I Can find the Sound Amplifier Bose in my Mercedes ?
4. i Showed you some connectors found in the trunk ( not the fiber ones ) . please see the 2 last Picture in my previous Post ) . Can you please tell me what those are for ?
Picture 1
Picture 2
The labels may give a hint to what the where the ends of the cable go, but they're mostly irrelevant as long as you use whatever you have there to complete the loop.
I just noticed that your Picture 2 has a splice connector already. Open that up and remove the 2 fibres to get 2 loose ends. Now join the 2 loose ends to the radio using the existing lines and connectors behind the radio. You may need that splice connector to add a short fibre piece to the end. I remember there were a couple of short fibre lines (they went nowhere) behind the radio when I opened mine up. Remember, a white end connects to the red end of the next fibre line. It is always white to red, white to red. If you're short a black connector, the dealer will also have them. They are sold in straight or 90 degree configurations. They also sell caps for those connectors to protect the ends of unused lines.
you were really helpful for me ... Thanks again
