Questing about shifting.
I have not post anything for a long long time. This weekend I brought a new C320 with manual shift. This is the first time I got a manual shift car. I have one quick question regarding up shift. I seem to have problem doing a smooth up shift. Every time I shift from first to second or second to third or higher I also end up jerking the car a little. I am new to driving a stick shift, so I am a little slow on the clutch, and I did not rev the engine too hight when I shift because it is still breaking in. I usually shift around 2000-2500. I do notice that if I shift around 3000 or a little higher the transition is a lot smoother. I want to know how to shift at a lower rpm, because I don't want to rev my car every time just to get a smooth shift. Any suggestions? Thanks!
OR
if you mean that when I want to shift to third. I clutch in and move the leveler to N, clutch out and move the lever slightly toward 3rd, and the lever will pop in 3rd?
Confused.....
Please help
2002 C230 coupe six speed C7 C5 Bose 36K miles Paprika
OR
Confused.....
Please help
There's a point when you are driving and there's no drag on the transmission, you are neither accelerating or decelerating, the transmission is spinning at the same speed as the motor. If you let go of the gas pedal then you are decelerating, if you step on it more you are accelerating. At this point you can shift your car out of gear and into neutral without the clutch. You can feel for this by putting pressure on the shifter towards neutral, when the rpms match the shifter it will feel loser and slide out of gear. Practice makes perfect.
Now to shift into the next gear from neutral, you have to anticipate what the rpm is for that gear for the speed you are going. You do this the same way, when you feel you are close, nudge the shifter into that gear, if you are off it will grind a little, no damage. I don't know if it's necessarily a recipe for disaster, drove my W201 for 200K miles with no trans problems (other than the first week when they replaced the trans because it was defective) and the original clutch lasted 150K miles.
Once you mastered how to shift without a clutch and matching the revs is seconds nature, you will be able to drive your car without anyone knowing you shifted. Also, this came in handy once when my clutch cable gave out on an old Mustang and when the clutch fluid leaked out on an old Triumph, so you never know when this trick will come in handy. If that happens to you, use the starter to get you going in first, then shift clutch free for 2 through 6.
So I want to know if I shift at 2500+ can I just lift up my clutch quickly and get back on the gas? I guess I am still not too precise on the gas paddle as well, so I sometime give too much gas or too little during shifts. Driving a manual shift is much more difficult than I expected, but it sure is fun!
I drive a 2004.5 230 Sedan 6MT. Sometimes it just does feel like you're forcing it from one gear to the next. These trans and shifters aren't the smoothest I've ever driven...and certainly not the short throw experience with other vehicles. Mine loosened up after 2,000 miles.
Also, this engine is fairly noisy - just don't be afraid of the revving sound, it is perfectly normal.
