Quick DIY guide to C203 Coilover Installation?
Old Jul 24, 2004 | 11:04 AM
s4play's Avatar
01 S2000, E46 M3, 99 ML320
hey guys,
I did a few searches and couldn't find anything. I'm sure many of you have done suspension installs and was wondering if you can give me a few quick tips. I've done many coil/spring installs before but just not on a Benzo.
Any tips or pics, advice?
thanks,
rick
Old Jul 24, 2004 | 01:00 PM
Jon200's Avatar
what cars did the do the suspension on?
Old Jul 25, 2004 | 12:46 AM
preyx's Avatar
'02 C230K Coupe
Although I didn't install my springs myself, I watched my mechanic do them, here's my observations (for C-class):
Front suspension is the standard strut setup. Nothing really special with these, just like any other car.
Rear suspension is wishbone-type. This means you'll have to compress the spring slightly (by pushing up on the member with a jack) in order to loosen the bolt holding the shock in place. Once the bolt is removed, the jack can be removed, allowing access to the spring (unbolt the shock at the top if needed).
The rear spring has a spring pad above it which can be changed to any of four thicknesses (this subject has been explained to death), don't forget to make sure you have it on correctly before replacing the spring into the suspension. To reinstall the rear suspension, compress the spring once again with the jack until the holes for the shock line up, then bolt it back into place.
Of course, with any suspension work, be sure to get it aligned. Good luck!
Old Jul 25, 2004 | 01:10 AM
KWiK's Avatar
2002 C230 : 2007 C230
You do not need to remove any shock bolts...You don't even need to remove the rear wheels. The only bolt that needs to be removed is the inner one on the lower control arm. The jack is used to keep the arm in place until the bolt is removed & then the arm can be lowered slowly until the spring is free.
Old Jul 25, 2004 | 01:13 AM
preyx's Avatar
'02 C230K Coupe
I stand corrected. I'm not too familiar with all the bolts and stuff on the suspension, so I took a stab at the name. But yeah, my mechanic only removed one bolt, I suppose that was it.
Old Jul 26, 2004 | 04:39 PM
s4play's Avatar
Ok I will answer....haha
We just completed the H/R coilover install and here are some interesting notes I found:
1) For the rear, it's not that bad but you do need to remove the one large bolt close to the tranny. On the driver's side, we had to drop the exhaust too to get to that bolt! We also removed the sway bar bolt to make it easier to access. The coilover adjustment goes on the upper portion but my complaint is that it's totally not adjustable without first removing the entire assembly if you need to raise/lower the car!
2) Fronts need to have the springs compressed before pulling out the entire assembly. The C-class front is very unusual in that the center bolt is part of the entire rubber assembly so it requires to be twisted onto the upper collar.
After doing the coil install, we realized the 19" rims were rubbing up front so now we need to get spacers
Anyone else with H/R coils had this problem?
rick
Old Jul 26, 2004 | 09:57 PM
preyx's Avatar
'02 C230K Coupe
I suppose since it's not a strut-type rear suspension, you can't do any adjustments through the top? Also, while you were under there, does it seem like a rear tower bar is at all pracitcal/possible? Again, since it's not a strut, seems like it's not really as useful.
I think I remember seeing people in the forum complaining about 19" rubbing, even with a more conservative AMG suspension kit. Hope that works out for you (and you don't damage your nice expensive rims!).
Old Oct 6, 2004 | 02:09 PM
otmal's Avatar
Is it really true that the front spring need to be compressed before
pulling out??????
I know the C-class front strut looks funny with only one bolt and a
black channel to hold on the top.
Can anyone explain the proper procedure for removing the front strut?
Old Oct 6, 2004 | 02:14 PM
KWiK's Avatar
This is not correct. The front springs do not need to be compressed before removal. Also, you do no need to turn the complete spring hat to remove it, the nut is not part of the entire rubber assembly(hat), just use the proper tool to remove the small locking nut and the hat will slip off.
Old Oct 6, 2004 | 07:26 PM
SUNILP's Avatar
2015 E250D
I second that. I have done this upgrade myself and the front does not need to be compressed before removal. The whole assy. comes out. You need a special tool to remove that nut on top though. I have it the garage. I will get part number later on. You will need a very good spring compressor. The best is Klann. Or go to a shop with a hydraulic compressor. Those stock springs are loooonnnnggg when you uncompress them.
Old Apr 12, 2005 | 03:26 AM
ms2005's Avatar
Sunman,
Just purchased the brabus springs for my 2001 c320 sport. Wondering what the special tool model number i need for the front coil disassembly? Planning to install springs next week. Thanks.
Old Jun 6, 2007 | 01:42 PM
Supratt85's Avatar
Would you guys mind posting a part number or link to that special tool that is needed to unbolt the suspension? Thanks.
Old Jun 6, 2007 | 02:32 PM
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Well, I don't know if there is a special MB tool, but one thing that will make your life easier is having a spring compressor.
Old Jun 6, 2007 | 03:30 PM
jolenicz's Avatar
2002 C230 Coupe
I think he means the MB tool to remove the retaining nut holding the strut cap on. According to the other forum, the part number is:
203.589.00.07.00
I can't find the picture of it right now, but it's basically a socket with two pins sticking out the end to fit in two holes in the retaining ring. I bought mine, and it was pretty handy, but you can probably make do with two small screwdrivers and some swearing.
Old Jun 6, 2007 | 03:43 PM
drexappeal's Avatar
203.589.00.07.00
Oh, okay. Now I understand. Not sure if the part number is correct, but that makes sense.
Old Jun 6, 2007 | 03:56 PM
rlee02135's Avatar
2004 C32 ///AMG
here it is: http://cgi.ebay.com/ebaymotors/Merce...spagenameZWD1V
MB dealers charge about $36 for this piece.
Old Jun 6, 2007 | 06:00 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
You dont need the tool, If you compress the springs first, then just use vice grips and you can get it off without any issues.
