New secret MFD menu?
C200 Kompressor
Hi,
I guess everybody in this forum is familiar with the ESP/dyno-mode menu on the MFD. "Normally" there are two screens in this hidden mode (the ESP-dyno on/off screen, and the screen that shows the oil-level, instrument cluster version etc.), right? I was foolin' around with it a while ago and guess what... I found one more hidden info screen. There were lots of numbers displayed (something in style with SW3... and some hex-values. I don't have a clue on what those numbers are supposed to show/indicate. Does anyone know???
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
Hi DtS,
I may be the only one on this forum NOT to know, but where can I find details on the ESP/dyno-mode menu? I don't know what that is, and I feel the need to play with something new.
Just put the key in the on position and push the left button on the instrument cluster for about 20 seconds until it beeps. Bingo, the diagnostic screens!
![Cool](https://mbworld.org/forums/images/smilies/cool.gif)
No, the button you use to reset the odometer on the edge of the instrument cluster. Its a little round fellow. Its also used for dimming the dash light level.
C200 Kompressor
Originally posted by cw203
hi..what do you refer when u said left button? the up button in steering control?
1. Turn key to pos. 1
2. Immediately press and hold the odo reset button for ~30 secs.
3. Now (if you were fast enough pressing the button after placed key in pos 1) you will hear a short beep.
4. On the left steering wheel button, press the one that looks like a paper-sheet under another paper-sheet (the lower right if I remember correctly)
5. Now you will see a new menu, that you can nav around just like any of the other menues.
6. To disable this menu, just turn key to pos 0, remove the key, and insert it again
C200 Kompressor
Hehe, almost forgot...
...to enable the third screen (wich I was talking about initially :o )in the hidden menu , press an hold the "up-arrow" button and the "+"-button simultaniously for ~15 secs.
After you have done this, please tell me what you see!
2002 C230 K
BT
C270CDI Avantgarde 2001 Sedan AMG rims and skirts
Re: Hehe, almost forgot...
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
This one is without the engine running:
![](http://www.verboom.net/images/mb/engine-off.jpg)
And this one is with the engine running:
![](http://www.verboom.net/images/mb/engine-on.jpg)
Ok, so I see numbers changing all the time, but what does it mean??
Mark
Thanks for the pics Mark! I also wonder what all the numbers mean. I don't have a clue....
anyone with some inside info??
Mark
C200 Kompressor
I'm bringing my car in for first service on tuesday. I will then show the service guy this thing. Maybe he knows what this is all about
Mark
C200 Kompressor
Originally posted by viper
These are event flags for the ECU and enable the technician to determine what sensors have been activated in the engine management system.
Hrmmm-
My first line under the "up arrow / +" menu has 3 lines
Most were stagnant, but the first line, second part, would go between 0044, 0046... then it leveled at 0046 and would switch to 004E?
Any ideas what that is?
Originally Posted by nukblazi
Hrmmm-
