2002 w203 c240 fuse #8 keeps blowing
W203 2002 c240, R107 1980 450 SL
Fuse #8 blows immediately when I replace it.
any suggestions where to start with this? I’ve already checked all the other fuses and they are fine.
apologies if this is a repeat of an old thread I couldn’t find looking through for the last three hours.
had the same problem
hey bro had the same problem with my cigarette lighter it kept blowing the fuse too for no reason
surfincello1 (08-15-2020)
Had to have the wire near the battery replaced. The wire coating had worn off between the alarm and the cabin after eighteen years. Everything works fine now.
To surfincello1, wire repair
Is there a chance you can show me where the wire is located?
I am fighting a similar issue with the StarDAS giving me an error of a broken wire on my alarm circuit.
Alarm Diag
I have traced the issue to the alarm bulb, the wires, connector and bulb will have to be replaced.
Future project when the weather calms down.
Thks
Thks
