Cannot track down this misfire
Old Aug 12, 2020 | 09:42 PM
Escott16's Avatar
2001 w203
Check engine light when wide open throttle above 4500 rpm. Code p0304 cylinder 4 misfire.
Replaced
-spark plugs
-mass airflow sensor
-valve cover gasket passenger side (along cyc 1,2,3)(needed done while doing this)
-tested fuel pressure and get proper pressure
-swapped coil pack and fuel injector with another cylinder and still constant misfire cylinder 4
Old Aug 13, 2020 | 05:13 PM
Russell Ormerod's Avatar
not a merc
A good start would be to tell us what engine you taking about!
also some history of how this misfire started. Previous work done?
Old Aug 13, 2020 | 05:22 PM
Escott16's Avatar
2001 w203
I am sorry didn’t even think to, it’s a 2001 C320 with 120k miles and it kind of came out of no where I noticed it trying to merge fast one day erased the code and the car runs fine and only does the misfire when above 4500rpm and I noticed my valve covers leaking oil into spark plugs so I changed the plugs and gasket hoping it was related but it wasn’t
Old Aug 14, 2020 | 12:14 PM
not a merc
Any work ever been done on the gearbox? Flexplate? Gearbox removed maybe?
Old Aug 14, 2020 | 12:30 PM
Escott16's Avatar
2001 w203
No work outside what I’ve mentioned
Old Aug 14, 2020 | 12:53 PM
not a merc
Okay. For that kind of misfire.. do you have DAS? Do a default initialization and recheck
Old Aug 14, 2020 | 01:10 PM
Escott16's Avatar
2001 w203
I do not. Just a scanner
Old Aug 14, 2020 | 05:56 PM
not a merc
Find someone with DAS
also you need scope the crank signal. I would like to see how it looks
Old Aug 14, 2020 | 06:10 PM
Escott16's Avatar
2001 w203
Is the scope thing something I can do. I have a decently equipped garage
Old Aug 18, 2020 | 03:59 PM
not a merc
Then post a print out of the oscilloscope signal from the crank sensor at idle speed. Showing 1 revolution of the crankshaft
