C240 Misfire
C240 Misfire
Hi all,
I've had a misfire for a while now, on idle it is in Cylinder 1, but spreads in high rpm.
I took it to an independant to have diagnosed and they determined it is plug wires.
Are there any recommendations for brand, I know Bosch is a good choice but I'm struggling to find a full set.
Any input is greatly appreciated!!!!!!!!
Plugs are good, changed just a couple months ago and the shop verified.
The wires in 1 are bad, and all other values looked good so there are probably a couple bad in other cylinders.
at higher rpm 4 5 and 6 start to stumble
from what I found it is easier/ cheaper to buy a set as soon as you need more than a couple
