C320 acceleration issues
Old Aug 2, 2020 | 11:30 PM
Escott16's Avatar
2001 w203
I have a 2001 c320 with 120k miles. I recently broke down with cylinder 1,2,3 misfire. I replaced the spark plugs because I needed to anyway and it fixed that misfire issue but I am getting a serious lack of power and misfire at acceleration that I didn’t have before that sometimes( 25% of the time) that does not throw any codes or lights. I hit the gas and it struggles and pops(exhaust) when accelerating then is fine after 5 seconds. Any suggestions. It’s perfectly fine on the highway and has full
power and only does this at very low rpm
Old Aug 3, 2020 | 02:37 PM
Russell Ormerod's Avatar
not a merc
New Maf
Old Aug 5, 2020 | 02:45 AM
tjts1's Avatar
C320
Check your fuel pressure. It should be around 53psi at all time even when you rev it. The symptoms you describe sound like a failing fuel pump.
