!! How To Make Light Blue !!
Old Aug 15, 2004 | 10:32 AM
  #51
SUNILP's Avatar
2015 E250D
I considered doing this mod for a friend but declined after I took a switch panel apart. There are too many led's in the car to change out. It would take days to do. I am sure if benz came with blue led's standard, people would be changing them to orange or some other color.
Old Aug 15, 2004 | 12:09 PM
  #52
psycho's poetry's Avatar
2004 C230 Kompressor Coupe
It would be awesome if somebody could produce a list or a kit to do the interior mod. I'd be interested in doing this mod. Those amber lights are one of the things I hate most about my interior.
Old Aug 15, 2004 | 01:09 PM
  #53
CitronC230K_03's Avatar
2003 Citron Green C230KMT
yeah but the guy who did it said it took him nearly a week to do. it does look cool and different. i wish we had white like the S-Class though.
Old Aug 15, 2004 | 01:20 PM
  #54
SUNILP's Avatar
2015 E250D
I think the instrument cluster is the only white part of the S class. All switches are amber.
Old Aug 15, 2004 | 01:22 PM
  #55
hmm, well all white switches and gauges would look cool. this mod would take too long just to solder all the LED's. you would have to remove every switch, button, gauge, etc. then take those apart.
Old Aug 15, 2004 | 01:43 PM
  #56
I don't know. If you had everything removed and prepared to solder, a proficient solderer who knew where everything went could easily do it with in an hour or two. I have done more and was much harder to solder(a 100 LED UV Spotlight with about a 9 milimeter space between the LED's). That took about three hours. The thing would be finding the right ones. From the picture there are some pretty rare sizes to find especially in blue.
Old Aug 15, 2004 | 02:05 PM
  #57
Wiedermann's Avatar
NA
Talking Changes
Mr. sunman:
You are correct!... like you said, the grass is ALWAYS greener on the other side...
Cheers!
Wiedermann
Old Aug 15, 2004 | 02:18 PM
  #58
Originally Posted by Wiedermann
Mr. sunman:
Cheers!
Wiedermann
the grass seems to be bluer on the other side Mario.
Old Aug 15, 2004 | 02:29 PM
  #59
Wiedermann's Avatar
NA
Talking Correct!
Mr. CitronC230K_03:
I stand corrected!!!... (You are DA' man too! )
Wiedermann
Old Aug 15, 2004 | 02:37 PM
  #60
HITMAN's Avatar
c230 kompressor
they arnt just white they are electroluminescent
any ways all white to me would make it look like a chevy truck or suv int.
  #61
So has anybody in this forum that speaks ENGLISH hase done that mod? If so where did you get your LED's from. I have wanted to do something with those lights for a while but I didn't think you could get them out of the MFD panel. So I am happy that it is possible. That and putting real aluminum panels in the place of the plastic textured ones and the interior should be perfect.
Old Aug 15, 2004 | 02:40 PM
  #62
HITMAN's Avatar
c230 kompressor
I dont think the center stack is plastic unless its dif. on the 04's
Old Aug 15, 2004 | 03:16 PM
  #63
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Ladies and Gentlemen
We have a volunteer.
Thanx for doing that Psycho. Please post when you got it finished.
Old Aug 15, 2004 | 03:20 PM
  #64
HITMAN's Avatar
c230 kompressor
i would love to do this mod but i think i would have to have it done unless i was to work little by little lol
Old Aug 15, 2004 | 04:31 PM
  #65
vadim's Avatar
'19 GLC 300, '19 TM3SR+
So, you want to take a lesson in English as well?
Old Aug 15, 2004 | 09:31 PM
  #66
I'll give it a shot. Just need to figure out where that guy got his LED's from. Never taken the gauges out before.
From what I can, tell my center stack is plastic unless, they coated it with a textured polyurethane. If you look real closely it doesn't actually have holes it is just a printed pattern covered with a textured clear enamal.
Old Aug 15, 2004 | 09:37 PM
  #67
HITMAN's Avatar
c230 kompressor
yeah thats why its called patterned aluminum
and from what i can tell its metal
Old Aug 15, 2004 | 10:20 PM
  #68
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
..... Just need to figure out where that guy got his LED's from....
Conrad Elektronik in Germany and they don't ship to the states.
Old Aug 15, 2004 | 10:58 PM
  #69
Well not a problem, I found another source. Gotta go do my homework on this. I have the most difficult job first of trying to figure out what the LEDs are.
Old Aug 15, 2004 | 11:08 PM
  #70
Well The large lamps are the climate like he said.
The common DT-LED is for the switches
I guess by Tacho he means Tachometer and the other gauges.
The others are pretty easy to figure out.
Old Aug 16, 2004 | 01:39 AM
  #71
Wiedermann's Avatar
NA
Exclamation W203 C class: Blue interior lights project
Mr. psycho's poetry:
I would suggest, get in hold of Mr. MadC32 who lives in Zurich (that is Switzerland ). Conrad Elektronik from Germany will ship to Zurich and have him send you the kit.
The kit is a whole bunch of LEDs of all sizes and small light bulbs... once you have the kit, finding the right bulb won't be the problem, saldering it will be the more challenging part.
Mr. Sunman even posted a comment where he almost did that project himself for someone else's car.
Another option is, here in the US, there are shops, many of them where you can get the same LEDs.. .the LED themselves are not any "special"... again, removing all the parts, headliners, soldering and so forth will be the reak task.
If you can get in hold of anyone that knows how to remove the center dash, the center cluster, headlinner you have 50% of your work.
Be advised (just in case) the ruler in the picture is in Centimiters! (not inches!) and also the LEDs on the picture would produce the same amber light... (the LEDs instead of looking yelloish will look blueish --the picture was posted for purposes of showing the size of the LEDs and bulbs, not color--
Cheers!
Wiedermann
Old Aug 16, 2004 | 02:04 AM
  #72
hey good luck on that mod dude!
Old Aug 16, 2004 | 02:12 AM
  #73
levelr123g's Avatar
they are using surface mount leds and they are readily avail from www.mouserelectronics.com. I have personally bouht many items from this comapny with no problems. Some color choices are
Super RED
SUPER INTENSITY RED
RED
SUPER YELLOW
YELLOW
SUPER ULTRA GREEN
GREEN
ULTRA PURE GREEN
ULTRA SUPER BLUE
SUPER BLUE
BLUE
ORANGE
SUPER ORANGE
ULTRA WHITE
Hope this helps.
The most expensive leds are super blue which are 4.08 a piece the cheapest are .52 a piece.
Old Aug 16, 2004 | 09:02 AM
  #74
cracker123's Avatar
05 CLK 320
good luck with your mod.
If Sunman says it is hard then "Houston we have a problem"
BTW the site with all the pictures what language is it in, Slovenian ? kidding
Old Aug 16, 2004 | 11:33 AM
  #75
thats the truth. sunman installed parktronic, aux heater, vented/heated seats etc. and is currently working on distronic and auto trunk closer.
Blue LED's, we dont need no stinking blue LED's.
