W203 AUTOMATIC Georbox issue? HELP ME
![Exclamation](https://mbworld.org/forums/images/icons/icon4.gif)
Hi Everybody:
Recently changed the automatic transmission fluid on my w203 220 CDI, 2005, and now i am having some issues. When i startup the engine it runs fine on P and N. but when i change to R and D car dies and shut off. I should wait 15 min until the car gets warmer or i should press the brake pedal very hard when i change from P or N to R and D for the car not to shut off and drive it.
I checked the fluid level at the dealer, and we added around two litter because it was missing , car worked ok for 10 days and now seems repeating the issue again , car dies on R and D while in N and P runs perfectly!
Any clue what might the issue be?
Might it be transmission leak ? or any other issue? i don't see signs of leaking on the ground when i leave the car overnight parked !
Please help me
Please help me
First time i used dextron III, second time.we used orginal mb oil suitable for w203
sump is not changed as far as i know
Well changing the oil and changing the oil because of water in the gearbox is a big difference. Problem can be in the valve body. Remove it. Strip and clean it. Also water could have got into the torque converter and the lockup clutches.
can the water be drained from torque coverter and the lockup clutches ? If yes , can this be done without removing torque converter?
2003 C230K Coupe Orion Blue
Just to make sure I understand properly. Is coolant mixing in your transmission? These things obviously should never touch each other if your car is functioning properly.
The car has a transmission fluid cooler in the radiator. Did your mechanic stick a new unit in there or one off a wrecker? Older Valeo radiators are known for destroying transmissions on these cars. If you have a used Valeo unit, switch it out with a new Behr one.
W203 transmission fluid leak
