Coolant mixing with engine oil w203
Old Jan 22, 2021 | 12:58 PM
albert waudo's Avatar
w203
What do you think of this explanation for coolant mixing with engine oil. Does it make sense.
We removed the engine from the chassis ,disconnected timing cover and engine oil pan to verify the cause of coolant mixing with the engine oil.
On removing the timing cover, we noticed one of the timing cover rubber seal missing.
The missing timing cover rubber seal was found trapped into the water jacket.
The seal had swollen and pressure from the coolant pump pushed it out of its position resulting to the coolant seeping through the joint/gap into the engine oil pan.
The oil cooler rubber gasket had hardened and flattened contributing to timing cover rubber seal getting swollen.
Old Jan 22, 2021 | 02:40 PM
slammer111's Avatar
2003 C230K Coupe Orion Blue
Sounds like someone had botched the job before. No reason why any seals would just "go missing" like that.
Replace the relevant seals and flush both fluids.
