MB325.3 coolant for W203 C32 AMG
Old Jan 25, 2021 | 07:43 AM
Hill Tseng's Avatar
S203 C32 AMG
我擁有一台2001年的C32 AMG,我購買了用於C32 AMG的冷卻液,然後我發現這種冷卻液 VOLTRONIC R32 符合MB 325.3規範(https://www.voltronic-germany.com/en...8917;目/ R32-冷卻液的-SF-en.html ),我不知道該冷卻液能夠在C32 AMG使用?
Old Jan 25, 2021 | 06:37 PM
slammer111's Avatar
2003 C230K Coupe Orion Blue
MB Bevo 325.3 coolants
Voltronic is not on the list. Use at your own peril.
Old Jan 25, 2021 | 10:25 PM
Hill Tseng's Avatar
S203 C32 AMG
thank for your feedback, if the coolant meets the MB 325.3 spec and is in the MB list, can I use it in my C32 AMG? Because I refer to MB document, it only shows that 325.0 can be used in M100 engine.
Old Jan 26, 2021 | 12:03 PM
slammer111's Avatar
Doesn't the C32 have a M112? According to the sheet above, the M112 can only use 325.0, 325.6, 326.0, and 326.6. 323.3 is still not on the list.
I would not assume that 325.3 would work just because the number is in between. For example, a car that uses DOT4 brake fluid can also use DOT5.1 brake fluid, but NOT DOT5 fluid.
Old Jan 26, 2021 | 12:53 PM
Hill Tseng's Avatar
S203 C32 AMG
Just out of curiosity, as discussed below, Glyn M Ruck seems to recommend 325.3 to replace 325.0.
https://mbworld.org/forums/c-class-w...ze-agents.html
https://mbworld.org/forums/c-class-w...in-fill-3.html
Old Jan 26, 2021 | 04:11 PM
slammer111's Avatar
I'd have to see some official documentation. The other way of course is to call a dealer for a coolant PN.
I have a different engine from you so I don't know if your engine has an updated coolant. I just know that mine doesn't. The last jug I bought a few years ago from the dealer was 325.0.
