MAF Sensor Readings on a 05 c180 Kompressor
Subscribe
Feb 19, 2021 | 01:00 AM
Hi Guys,
New to this forum, so if I am not posting this in the right place, I apologize.
I have been having poor acceleration issue (in a 05 C180 Kompressor W203) that I am trying to troubleshoot. I have looked at PCV Hose which seems to be fine. Now I am looking at the MAF sensor. My OBD reader's MAF PID, gives me 2 g/s at idle which sounds about right. BUT, at 2500 RPM I am only getting 8 g/sec. Shouldn't it be around 15? Can anyone share this info or run this test on their car? Thanks in advance.
Reply 0
Feb 19, 2021 | 12:28 PM
If there was a problem with the MAF I assume some sort of CEL would show up.
Did you check all 3 of the crankcase breather hoses and the check valve?
Reply 0
Feb 20, 2021 | 05:34 AM
Quote: If there was a problem with the MAF I assume some sort of CEL would show up.
Thanks,
I checked just the PCV hose under the air filter housing. As for CEL, I did have one for "cylinder misfire detected". Nothing else. But I am just trying to understand the PID values. I have been led to believe that the air flow rate should be almost double than the ones I have @ 2500 RPM. Hence my question / request. Thanks for the reply though, I will definitely look into it. Do you have any suggestion about the other breather hose locations though
Reply 0
Feb 20, 2021 | 05:56 AM
If a cylinder misfire is detected, try swapping an ignition coil on the bad cylinder with one from a good cylinder and see if the problem moves. Ignition coils are known to go bad.
M271 crankcase breather hoses check valve replacement Start at post #22.
Reply 0
Feb 20, 2021 | 07:34 AM
Quote: If a cylinder misfire is detected, try swapping an ignition coil on the bad cylinder with one from a good cylinder and see if the problem moves. Ignition coils are known to go bad.
Thanks Mate,
Did just that. But to my frustration, the problem just goes away after restart. I had this same code and problem a year ago (Same shaky tractor like firing due to the missing cylinder). Had the coil for that cylinder and all spark plugs changed. Now it resurfaced (but as I said, it went away after a restart) . The CEL also cleared after a few cycles. So I am trying to look at it from other possible angles. Would you happen to have any PID readings for MAF sensor at 2500 RPM by any chance. Once again , thanks in advance
Reply 0
Subscribe
Currently Active Users (1)
