Control module on the driver's door is dead
Old Feb 22, 2021 | 12:34 PM
Da Huang's Avatar
2006 Mercedes Benz C280
All the electronic functions on the driver's door of my 2006 Mercedes-Benz C280 are lost. I checked the fuses but they are all good. Then I went to the local mechanics, I was told that the control module is dead but they cannot get it fixed because reprogram is needed. Now I have to go to the dealership to get it replaced and reprogrammed. Does anyone know roughly how much will it cost?
Old Feb 22, 2021 | 07:05 PM
slammer111's Avatar
2003 C230K Coupe Orion Blue
Probably won't be cheap. Also depends on the country you're in. You might want to list your country in your signature.
Old Feb 23, 2021 | 12:02 AM
Da Huang's Avatar
Thank you for your reply. I am in US.
Old Feb 23, 2021 | 02:54 AM
slammer111's Avatar
You're probably looking at a few hundred bucks. If you're the DIY type, see if you can purchase the module and swap it out yourself after they program it. Knowing the dealers they probably won't allow for that.
I'm unaware of any version coding required for those modules. The dealer often won't tell the truth either. If you want you can roll the dice with an eBay unit. Just make sure the PN is the same or compatible.
Old Feb 24, 2021 | 03:41 PM
Russell Ormerod's Avatar
not a merc
Just buy a used one plug it in and be happy
