DIY - setting up the AUX input for iPod, mp3 player, etc.
Rating: Thread Rating: 23 votes, 4.65 average.
Old Mar 19, 2008 | 08:50 AM
  #476
ram_rtg's Avatar
C200K Jul 2004
Originally Posted by "G"
Also how do i know if i have a becker? I thought i had a harmon/ kardon?
This is a Becker 6021 (Audio 10 CD):
http://www.audio-10.com/images/stori...dio-becker.jpg
cheers
Old Mar 19, 2008 | 09:26 AM
  #477
"G"'s Avatar
"G"
2005 e55 amg
Hmmm are beckers supplied in usdm mercs?
Old Mar 19, 2008 | 09:48 AM
  #478
ram_rtg's Avatar
C200K Jul 2004
Sorry I'm not sure about that....
Old Mar 25, 2008 | 01:03 PM
  #479
basuki's Avatar
c240
2002 c240 - is aux input possible
Can someone suggest the methods described in this thread can be used to setup AUX inout for a c240 - 2002 model.
Old Apr 15, 2008 | 03:47 PM
  #480
nuphan's Avatar
'06 C350 SS
Does anyone know of an online site that sells the aux cable cheaper than the dealership? There's used to be a site called trademotion.com which doesn't exist anymore.
Thanks.
Old Apr 26, 2008 | 07:05 PM
  #481
itzwill's Avatar
06' C230
i drive a 2006 C230, and i was wondering what tools i would need to install the AUX cables?
Old Apr 27, 2008 | 08:24 AM
  #482
ctC230K's Avatar
excites your girlfriend
tools? just a screwdriver to pry up the doorsill panel
Old Apr 27, 2008 | 11:16 AM
  #483
Benzben's Avatar
'05 C230K SS
You'll need a flat head screwdriver to pull up the door sill panel and to pop out the screw cover on the side kick panel. Then you'll need a phillips head to unscrew the one screw holding the side kick panel on. You might also use the flat head to pry off the side panel to the right of the glove compartment, but it comes off pretty easily.
Old Apr 29, 2008 | 05:38 AM
  #484
itzwill's Avatar
06' C230
Thanks. appreciate it. gonna try to get it done sometime this week when i pick up the cables.
Old Apr 29, 2008 | 08:29 AM
  #485
ctC230K's Avatar
yeah what he said! just a couple screwdrivers
Old May 20, 2008 | 08:29 PM
  #486
allhwydriving's Avatar
2017 E300, 2017 GLC300
What are the options for a 2006 C230 with Sirius, but no changer (only dash)? Can I still get the AUX in?
I was considering the iPod integration kit, but after using it on my sister's '07, I came away completely frustrated. I'd rather use the iPod to control the system.
Old May 27, 2008 | 10:56 AM
  #487
svir's Avatar
Audi RS6 MTM
My '07 C230 with CDC does not have the white plug!
Old May 29, 2008 | 07:46 PM
  #488
Guys, this is the easiest install ever, and I have a history of breaking stupid plastic parts when working on my car. When I put it back together, it fit just like before. On my 2006, the white connector was right where it should have been. You just have to peel back some hard plastic to get to the bundle of wires.
There are three pieces to remove, and the lower sill piece does not even have to come out - just pull it up enough to get to the pillar piece (the next piece). That one comes out completely, and so does the top piece next to the glove box. Snap it all together, cover it up, and you're done.
Thanks for the pics and advice. The dealer said this would take at least an hour. I did it in about 30 minutes, including the time it took to find the right Torx driver.
Old May 30, 2008 | 02:55 PM
  #489
Defiant's Avatar
97 J30\71 220 gas 4-speed
I'm curious why my 2003, with no provision for the adapter, still has the punchout in the side of the glovebox liner. Is there some other "aux" or other accessory that Mercedes was putting there?
Old May 30, 2008 | 06:40 PM
  #490
It probably cost more to produce a different glove box just for the cars without the aux. There's no reason to have a different design, since you can hardly see the punch out if you leave it alone.
It's like the question 'why do drive up ATMs have braille on the keypad?" Well, it's definitely possible that a blind person might walk up to the ATM, but it's more likely that it cost more to do a second run of metal keys without the braille.
On a sidenote, the aux in is definitely NOT a line in. I have to crank my mp3 player to about 70% of it's maximum volume to get the signal level to what the FM radio puts out. When I do, it sounds great though.
Old May 31, 2008 | 05:48 PM
  #491
Defiant's Avatar
Sure, but 2003 was before this adapter was made, isn't it? What were they up to? Is there some other AUX that was available for the earlier models? Was the Mercedes iPod kit available earlier?
Old May 31, 2008 | 06:26 PM
  #492
UK-C200's Avatar
RHD C200 Sport Coupe, RHD SLK-55, LHD SLK-350
Aux was available if you had a COMAND...
Old May 31, 2008 | 10:29 PM
  #493
ram_rtg's Avatar
C200K Jul 2004
How difficult would it be to replace bekker 6021 with command or is it not compatible with D2B?
Old May 31, 2008 | 10:52 PM
  #494
UK-C200's Avatar
It's a painful, expensive experience, but yeah, it can be done. Personally, I'd go aftermarket before I'd stick in a COMAND.
For pre-facelifted C's, without COMAND, your best option is one of the D2B AUX or iPod interfaces. Most of these replace the CD changer (literally and figuratively), the Denison Gateway 500 is the only exception that I know of that allows you to retain the CD Changer.
One caveat to remember is that on the pre-facelifted cars, the HU's don't understand CDTEXT, so you do NOT get nice displays of song title or artist - despite what some of the adverts on these interfaces say.
Old Jun 4, 2008 | 04:26 AM
  #495
s.atwal's Avatar
2002 C240
Will this work for a 2002 C240?
Old Jun 5, 2008 | 08:38 PM
  #496
codegeek's Avatar
A car
Many thanks to the people that have posted how-to comments on this board (this thread and others).
I have an '05 c230K Sport that makes a great wrapper for my RoadyXT XM receiver. The RoadyXT sits nicely in the front part of the ashtray assembly, but will not close if the receiver is in the cradle. I decided not to get the '04 c230 ashtray assembly because it didn't look like the Roady XT would fit very well and I didn't want to make it a "permanent" install be hacking up the cigarette lighter. The RoadyXT is a removable receiver so I have one cradle for it in the house and another in the car. It matches nicely with the aluminum around the shifter, so I don't mind leaving the receiver visible most of the time. It doesn't stay in the car at night anyway.
For around $100 I was able to connect my RoadyXT to the aux. input cable that I purchased from the local MB dealer. I was also able to run an additional cable to the center arm rest console for my iPod. That includes a ground loop isolator to get rid of the whine thru the speakers caused when I accelerate.
Supplies/Cost
6 foot 1/8" extension cable: Had one on-hand (Probably about $5 at RadioShack)
Two tap-in squeeze connectors: Had two on-hand (around $2 for 10 of them at RadioShack)
Aux. input cable: $52
1/8" headphone splitter: $5
Ground loop isolator: $17
12VDC acc. outlet cable: $8
1/8" elbow adapter $4
1/8" to stereo RCA Y cable $7.50
I needed that last cable because the ground loop isolator only came with one end configured for a 1/8" jack. Make sure the cable connects to the ground loop isolator. The RCA ends should be female.
Because of all the help on this forum, the only issues that took some consideration were:
1. connecting to the correct power and ground cables on the back of the cigarette lighter. My neighbor had a multimeter so that wasn't too bad.
2. Routing all the cable in a clean manner. The majority of the extra "cable" ended up (hidden) under the glove compartment. The fuses in the RoadyXT power plug and the 12VDC acc. outlet are accessible by lifting out the carpet next to the center console on the passenger side.
3. The splitter which is plugged into the aux. input in the glove box is a little loose, so it caused a bit of a problem when the cables moved around. Securing the cables a little better seems to have helped. The problem manifested as no sound or only sound on the left side (similar to using a mono instead of stereo cable).
In my humble opinion the end result looks pretty clean. I'll probably end up using the remote that came with the RoadyXT for changing channels, but I like the position (in the ashtray) better than in the armrest or pulled out of the armrest and placed behind the shifter while I drive (which is where it was originally).
Attached Thumbnails DIY - setting up the AUX input for iPod, mp3 player, etc.-roadyxtinashtray.jpg   DIY - setting up the AUX input for iPod, mp3 player, etc.-3.5auxininconsole.jpg
Old Jun 19, 2008 | 03:59 PM
  #497
lapi's Avatar
2006 c230 SS
Originally Posted by nuphan
Thanks. I'm just pulling it rearward to to back of the car right? I could have sworn that I applied force on it and it wouldn't move. Also do you remember which part of the a-pillar did you hold to pull it off? Thanks again!
were you able to pull it apart? I am still trying to open it :-(
Old Jun 19, 2008 | 09:16 PM
  #498
nuphan's Avatar
'06 C350 SS
I haven't tried since then but I'm planning to revisit this later on. I wish someone would make a video showing this and place it on youtube.
Old Jun 19, 2008 | 11:46 PM
  #499
lapi's Avatar
2006 c230 SS
Finaly got it working!.
For those who still trying to figureout with the yellow thing on the A-piller.
Remove the screew using the torx driver head. Then pull the front part of the plastic thing. Now, the only parts holding the plastic should be the two yellow clamps. It is actually two 'E' shaped clamps. And the top line of the 'E' has a reversed 'c' attached at the end. The E is attached to the body(do not try to use screwdriver to pry the yellow thing apart). Now, try pulling the plastic towards the side (near one clamp). (towards your left side when you are sitting on the passenger seat, NOT to the rear of the car). You need to use some force, since the clamp is tightly holding the plastic thing.
If you need any assistance, please let me know!
Thanks.
Old Jun 20, 2008 | 10:59 PM
  #500
lilbabybenz's Avatar
2005 C230 Kompressor
Install Pictures??
I really wanna do this, but, is it just my computer or are the pictures for the install gone? if they are, does anyone have them so that i can do this?
Any help would be GREATLY appreciated..
You have already rated this thread Rating: Thread Rating: 23 votes, 4.65 average.
