Bolt size help for control arm front passenger
Does any know the bolt and nut size for the bolt on the outer control arm bushing There are 2 bushing , the forward one and rear one and then the balljoint . I may need to cut it and I want to get the exact same size.
IF you are on the passenger side I when you take the tire off it's the bushing on the left or rear of the lower control arm . For all I know they are the same length both Inner and outer but I could be wrong..
